RV.Net Open Roads Forum: Class A Motorhomes: Kitchen and Bathroom fans
 > Kitchen and Bathroom fans
Executive
Posted: 09/19/20 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Branson N Tucson wrote:
snip/ "Tried checking the fuses in both areas by the brake peddle and in bedroom area. Boy alot of fuses to check. Can anyone help narrow the search area down for the bad fuse.
Thanks for the help.
By checking, do you mean you looked at them or used a meter. A visual can often look good but it's failed. Use a meter for accuracy. Mine will not come on if the vent is not opened. The fact both are not working indicates a faulty wire somewhere so that's a good thing. That is, assuming they worked at some point in time....good luck...Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
ArchHoagland
Clovis, CA, USA
Posted: 09/19/20 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
Did the fans ever work since you bought the motorhome?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Ed Manifold
Rescue California
Posted: 09/19/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
make sure vent lids are in up position.
Ed & Sharon
2002 Phaeton
2001 Jeep Wrangler Toad
