RV.Net Open Roads Forum: Fifth-Wheels: Real-life experience blocks to aid 6-point leveling system
 > Real-life experience blocks to aid 6-point leveling system
Campinfan
Washtenaw County, Michigan
Posted: 09/19/20 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
I carry 2 sets of blocks (the plastic stacking type), but have not has to use them yet.
______________________
2016 F 350 FX4 4WD,Lariat, 6.7 Diesel
41' 2018 Sandpiper 369 SAQB
Lovely wife and three children
Retired JSO
North Georgia Mountains
Posted: 09/19/20 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
While it’s unneeded to get level, I use the blocks under the pads to shorten leg extension that helps in limiting movement felt inside.
Edd505
Elephant Butte, NM
Posted: 09/19/20 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
TenOC wrote:
We have just purchased a new-to-us 5th wheel trailer with six-point leveling system. Watching videos on how to use the six-point leveling system it states that there is no longer any need for wood or plastic blocks underneath the wheels to level from side to side.
What is your real-life experience on the need for some type of block under the wheels to aid the six-point leveling system?
Do you carry any blocks with you?
Yes you can do without them, BUT. The shorter the legs extend the less "wobble" you get walking around inside. I had legos left from my prior RV's and use them every time to keep movement down. They cn also be used to change flats, build a ramt with them and pull the good tire up it, now you can change the flat, no jack needed. (I do carry one just in case)
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
MikeRP
Westerville
Posted: 09/19/20 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
I use Anderson Jack Blocks. They work very well. I have 4 of them. 90% of the time they are on the jacks on either side of the wheels. I use one or two LEGO blocks under the front jacks.
I’ve had a couple of camp sites that I had to use the blocks under the front jacks.
I’ve also had maybe 2 sites that were horribly in level side to side. In that case one side of my wheels were lifted off the ground. So I manually leveled the coach by raising the off the ground wheel’s respective jacks a bit and placed LEGO blocks under the tires, let the jacks back down so that the tires were not off the ground.
In my opinion the Anderson Jack Blocks are indispensable. Plus they are wider which gives the jacks stability being shorter and the wider on the ground. Also they are magnetic and very easy to use.
* This post was edited 09/19/20 06:31pm by MikeRP *
joelc
Cedar Point, NC
Posted: 09/20/20 11:32am Link  |  Quote  |  Print  |  Notify Moderator
RobWNY wrote:
I found that I would lift my tires off the ground on many occasions when on uneven ground without using the leveling blocks. I don't want my tires off the ground EVER!
You might find that necessary to do your breaks or a flat tire.
ACZL
UPstate,NY
Posted: 09/21/20 09:33am Link  |  Quote  |  Print  |  Notify Moderator
We use 2-6x6x24" for rearward most legs and I cut up a 2x10 into 16" lengths and screwed 2 together for a total of 8 "pads" if you will. These get placed under the remaining legs. There have been at time when only 1 "pad" was put under the leg due to close proximity of left to ground to begin with. As others have said, the less extension of the cylinder, the less movement in 5er. Likewise, a couple of times, 1 set of wheel have been lifted off the ground, but the coach doesn't go anywheres.
I have used the boards (pads) a couple of times under the legs to lift tires off the ground for various reasons. Not for very long tho. IF I have to remove both wheels on same side, I then add weight appropriate jack stands under the frame in front and rear of tires. Course this is when I'm home. Should this be necessary on the road, think I'll call road service.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
MNRon
Tennessee
Posted: 09/21/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Regarding lifting wheels off of the ground - MORryde lifted our 16,000lb coach with the 6pt LIppert levelers for two day while they removed our suspension and replaced it with IS. I also have lifted each side completely to do bearings and replace tires (always have jack stand under ‘just in case’ if I go under). We’ve also camped many times where one side is lifted off of the ground.
I’m not concerned at all about having hydraulic levelers supporting the whole weight of vehicle (have safety backup if You go under). We do have IS suspension though, might be concerned about inverting leaf spring suspensions if wheels are far enough off of ground.
Ron & Pat
2013 Silverado 3500 Duramax SRW
2019 VanLeigh Vilano 320 GK
Splashers3
Oakville, MD
Posted: 09/22/20 05:15am Link  |  Quote  |  Print  |  Notify Moderator
I have always used 6x6 blocks under the leveling pads to avoid getting a stroke error. I went to Lowes and bought nice large handles, which makes carrying and grabbing the blocks much easier. They go in the bed of my truck for easy access and are the first thing we do when setting up.
Only on a few occasions did one side of the wheels lift off the ground.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
sdfiver
Rapid City, SD
Posted: 10/02/20 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
We made 6 "pads" out of 12" square 3/4 inch thick marine grade plywood,2 pieces thick screwed together with deck screws. Painted them white. We've been using them almost 20 years so they're holding up very well. We use them under our 6 point hydraulic leveling legs every setup. Helps prevent settling on soft ground and doesn't leave rust stains on concrete pads. They ride, 3 to a side, in the truck bed in front of the hitch so it's easy to reach over the side to get them when setting up.
2016 F-350 6.7L Super Duty Platinum
2019 Heartland Bighorn 3760EL
kennethwooster
Perryton Tx USA
Posted: 10/08/20 08:11am Link  |  Quote  |  Print  |  Notify Moderator
I carry a few plastic blocks. However went to one park this summer and they put me in a very unlevel spot. They brought blocks so we could get level. Othrtwise I have never used blocks under anything. God idea to have something.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
