RV.Net Open Roads Forum: Fifth-Wheels: Real-life experience blocks to aid 6-point leveling system
 > Real-life experience blocks to aid 6-point leveling system
Super_Dave
Harrisville, UT
Posted: 10/08/20 10:48am Link  |  Quote  |  Print  |  Notify Moderator
FWIW, leveling blocks under the jacks hasn't prevented my tires from coming off the ground on the low side. It just prevents the low side jacks from getting an out of stroke error. Blocks need to go under the wheels to prevent them from lifting off the ground.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
Cummins12V98
on the road
Posted: 10/08/20 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
What is wrong with tires being off the ground?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
texanrvr
Posted: 10/08/20 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
There is no downside to lifting the tires off the ground when leveling. There is a CYA suggestion from Lipper NOT to use the jacks to change tires, but I have seen it done often. I have used the hydraulics for Discount Tires to change or service my tires and my dealer used them to service my wheel bearings.
Back when the Level Up was new, the inventor used his own Mobile Suite trailer completely off the ground to demonstrate their strength.
Their lawyers put a stop to this.
Jay-Driver
Stella-Director of Operations and Navigator
Cassie-Schnauzer
'11 Heartland Landmark
2010 Dodge 3500 DRW
SLT
Cummins12V98
on the road
Posted: 10/08/20 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have been setting at my Summer Residence since May with two tires off the ground, no ill effect.
ford truck guy
Pennsylvania
Posted: 10/08/20 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Each of my 6 rams are rated for 13,000#
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
obie311
Aux Arcs
Posted: 10/13/20 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
I'm guilty too of lifting wheels off the ground with my 4 point leveling system. I primarily plead ignorance of the system.
6 points may be OK but I would think the more contact points you have with ground (+4 w/ tires) the more stable you will be and the less chance of tweaking the frame.
I also like the theory of using as little stroke as you can (thru leveling blocks or cribbing) keeps the legs telescoped as much as possible and intrinsically more stable.
