RV.Net Open Roads Forum: Tow Vehicles: How much do you really need?
Search only in Tow Vehicles
 > How much do you really need?
paulfredricks
CT
Posted: 09/18/20 08:55am Link  |  Quote  |  Print  |  Notify Moderator
We are camper shopping. Have seen a few that have a GVWR of over 9000 lbs. That is too much for our tow vehicle. But then I see the dry weight is around 6500. The cargo capacity is around 3,000 lbs. We would never carry anywhere near that since we camp at full service campgrounds and don't need to haul around a lot of liquid, and we pack light anyway.
Should the GVWR be the deciding factor here? Or should some reasonable estimate on possible towing weight be more appropriate?
2004 Starcraft 215SSO
2014 GMC Yukon XL Denali
goducks10
There
Posted: 09/18/20 09:06am Link  |  Quote  |  Print  |  Notify Moderator
You're right to think along those lines. GVWR is semi worthless but it is relative to how the trailer is built IMO.
I had a smaller 5th wheel prior to our current TT that had over 4,000 lbs for CCC. UVW was around 7300 lbs. No way could I ever load 4,000 lbs in it.
Under normal loading expect to add around 1,000 lbs. I know from my own experience that I carry about 1500+/- lbs of stuff, but some is add ons like extra batteries, bike rack, solar panels, etc.
When shopping or browsing for fun I always look at the CCC to see how my 1500 lbs would work. GVWR never factors in. CCC is the most important number for me.
Add your 1,000 lbs to the trailers stickered UVW and that's close to what you'll actually be towing.
valhalla360
No paticular place.
Posted: 09/18/20 09:34am Link  |  Quote  |  Print  |  Notify Moderator
If you already have a camper take it to a CAT scale and see what it weighs compared to the empty weight...that will give you your current cargo weight.
UVW of the new trailer + current cargo weight should be a decent estimate for the new rig. I would probably bump that up a bit (maybe 500lb) as nature abhors a vacuum and big rigs with lots of storage (ie: vacuum) tend to get filled.
If this comes in below the GVWR, you have a reasonable basis for using your calculation over GVWR.
Keep in mind 3000lb CCC is more than most RVs have, particularly smaller non-toy haulers. 1000-2000 CCC is more common and it's very easy to max that out, so lacking better information, is where the recommendation to use GVWR comes from as most people have no clue what their actual cargo weight is.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Sjm9911
New Jersey
Posted: 09/18/20 09:58am Link  |  Quote  |  Print  |  Notify Moderator
I don't tow anything that i can overload. Ots easy to say i will not tow with full tanks etc. But it does come up, so i would definitely add the weight for full tanks, so waste water, reguler water , propane etc. After adding rhat it add you stuff. Then see how close your are. You will be surprised how much stuff you buy and it all adds weight. I seem to get a new something or other each year, and never get rid of anything. I rather tow a lighter camper then suck wind up a hill. Not saying it cant be done, just not worth it.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Bumpyroad
Virginia
Posted: 09/18/20 10:53am Link  |  Quote  |  Print  |  Notify Moderator
yep, and 1500 lbs. would be a "normal" cargo weight.
bumpy
dodge guy
Bartlett IL
Posted: 09/18/20 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have said this all along. I always recommend to add 1200-1500lbs to the dry weight.
Our old TT had a 4100lb CCC! It wasn’t a Toy Hauler. Just an overly built TT. It scaled at 9300lbs loaded for a trip. It’s dry weight was 7100lbs. Yes I pack heavy. 2 adults and 2 kids. and a 100lb German Shepard at the time. I also packed heavy knowing I had more than enough CCC in the TT and my Excursion was more than capable.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
paulfredricks
CT
Posted: 09/18/20 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone.
We don't have a new camper yet, just figuring out what we need.
We did unload the old camper and it's all in boxes. I am going to weigh everything and see what we used to carry. I know a new camper that's bigger will carry a bit more in theory.
jaycocamprs
Ringgold Georgia
Posted: 09/18/20 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
How far are you planning to travel, and what kind of drive do you want? I've been under trucked, under powered, about right and more than I need. I sure like more than I need. Your choice.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Beverley&Ken
Tottenham,Ontario
Posted: 09/18/20 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
When you are shopping, check to see what is included or not included in the Dry / UVW. Battery(ies). These would also have a big impact on tongue weight.
Do different manufacturers use different criteria, use the weight of base unit, NO options. Or do they actually weigh each unit when It comes off the line. There could be several hundred pounds different before starting to load your things.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
time2roll
Posted: 09/18/20 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
I always recommend keeping the GVWR within the tow rating.
675w Solar pictures back up
