RV.Net Open Roads Forum: Best portable heater (30 amp) for my rv?
 > Best portable heater (30 amp) for my rv?
rk911
DuPage County
Posted: 09/18/20 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
gbopp wrote:
If you want quiet, get an oil filled heater. They take up more space but do the job.
Otherwise, get the heater you like. As said, they are all about 1500 watts.
Even the cheap ones.
our 1500-watt fan heaters are whisper quiet and take up virtually no space.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
ksg5000
Oregon
Posted: 09/18/20 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Lots of opinions on what to buy ... but running an electrical heater on lower setting often creates more heat because they tend to shut off prematurely running on high. Two heaters run on lower settings on separate electrical outlets will often generate enough heat to keep the RV warm.
Kevin
rhagfo
Portland, OR
Posted: 09/18/20 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
Personally I hate portable electric heaters. We installed a Cheap Heat electric add on unit to our gas furnace. Not cheap to buy, but heats the basement also, provides 1,800 watts on 30 amps, and 5,000 watts on 50 amp. We also have an electric fireplace heater that will work well in really cold weather.
Camping near Pearsonville, CA
Posted: 09/18/20 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
750 watts keeps my TT warm but not my tanks. How are you warming your tanks?
mchero
Henniker, NH
Posted: 09/18/20 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
The very reason the question was posted. Lots of opinions/suggestions!
For those of you using electric heaters, make sure you don't overload your circuit(s). I strongly suggest people inspect their AC panels . I found a loose neutral connection on the bus bar that was starting to overheat turning the white insulation brown. Caught it before it fried the bus bar! Don't want to find out the hard way you have a loose connection.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
gbopp
The Keystone State
Posted: 09/18/20 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
I stand corrected, thank you. I'll have to check them out.
pianotuna
Regina, SK, Canada
Posted: 09/18/20 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
My preference is for no one type.
If there is a frozen compartment--a radiant heater is best. I've been able to meld the ice on the seal.
If there is a cold floor--electric heated carpets are best.
If there is room in the bedroom, a pair of oil filled, one on each side of the bed, may be the most comfortable.
If size is a concern, then fan based ceramics work a charm.
I keep a 240 volt incandescent bulb fed with 110 volts, on a mechanical thermostat beside my water pump.
To heat 100% electrically, replace the cold air return grill on the furnace with a twindow fan. In my RV that keeps a small amount of warm cabin air circulating through the duct work for the furnace, preventing plumbing system freeze ups.
My peak wattage in the deep cold is 7700 watts, and the continuous load is 5.4 kwh.
I do use my autoformer to keep the voltage up, so I get the full number of watts from my various and sundry heaters.
I've boondocked at -37 c (-34 f).
Regards, Don
pianotuna
Regina, SK, Canada
Posted: 09/18/20 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Lwiddis,
I replaced the furnace return air grill with this:
It pressurizes the duct work and keeps the plumbing from freezing up. It is controlled by a mechanical thermostat which is tucked against the outside wall inside the kitchen cabinets.
coolmom42
Middle Tennessee
Posted: 09/18/20 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
CA Traveler wrote:
We have 2 of the small cheaper 1500W ceramic heaters that are common to Walmart etc. They are easy to store and you can run 2 on high (25A for both).
I second this. Unless it's really cold, you may need only one. I've used one in a 25' trailer and it would heat up the place really fast.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
rk911
DuPage County
Posted: 09/18/20 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Hi Lwiddis,
I replaced the furnace return air grill with this...It pressurizes the duct work and keeps the plumbing from freezing up. It is controlled by a mechanical thermostat which is tucked against the outside wall inside the kitchen cabinets.
got a link to share, pls?
