RV.Net Open Roads Forum: Powering multiple low voltage devices in the truck
 > Powering multiple low voltage devices in the truck
philh
Belleville MI
Posted: 09/19/20 07:50am Link  |  Quote  |  Print  |  Notify Moderator
It's getting to be a wiring mess in the F150. In a year, we're ordering a SD.
When towing, I have
  • Rear trailer camera
  • GPS (like to run both this and Waze when towing)
  • Front dash cam
  • TPMS (is the Ford Kit worth it?)
  • 2 phones
Would it make more sense to get the overhead switches on the SD and wire things back to the fuse box? Any other suggestions to control the explosion of wires
BarneyS
S.E. Lower Michigan
Posted: 09/19/20 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Moved to Tech Issues forum from Towing.
Camping near Pearsonville, CA
Posted: 09/19/20 08:31am Link  |  Quote  |  Print  |  Notify Moderator
I don’t need a rear camera when moving forward. My GPS, when on, is on the dash screen. Neither of our phones needs constant charging.
corvettekent
Marysville, WA
Posted: 09/19/20 08:35am Link  |  Quote  |  Print  |  Notify Moderator
I have a couple of these installed behind my dash and wired to the fuse box.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
enblethen
Moses Lake, WA
Posted: 09/19/20 08:36am Link  |  Quote  |  Print  |  Notify Moderator
I would run some of the items on a dedicated fused circuit straight from the battery and not through the factory fuse block.
GPS, front dash cam and cell phone chargers would be connected to this source.
I am guessing that they are all USB type connection. They would not draw that much!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
delwhjr
TX
Posted: 09/19/20 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have one of these mounted in the inside bottom of the center console:
Power Box
It connects to the 12v aux connector in the console.
And one of these on the top:
Tray
I ran long usb to micro usb or c connectors depending on the device under and through the trim pieces on the console and door jambs. My GPS has a 12v plug which had a long enough cord to allow it to be routed under the trim.
I am running a phone, GPS( the one in the truck is not suitable for towing), TPMS monitor, rear observation monitor, and a dash cam through all this.
2019 F250 Crew 4x4 6.2
2019 Rockwood UltraLite 2608BSD
mobeewan
Hampton, Va
Posted: 09/20/20 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
On my previous truck I purchased an add on fuse block with 8 or 10 flat blade fuse slots. I mounted it high up on the insid right kick panel and ran an 8 gage wire to the battery. I added a 30 or 40 amp fuse in the wire near the battery. That gave me plenty of additional power for adding a CB radio, stereo speaker amplifier, cigarette lighter plug for a spot light and circuits for any other 12V DC toys I added.
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 09/20/20 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
ajriding
st clair
Posted: 09/22/20 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
and cell phones?
The safest thing to do, which will add more wires, is to power everything off a little inverter.
What happens with modern vehicles is the electronics you have plugged into a DC outlet can talk to the vehicle in some instances. To eliminate this the power inverter seperates the electrical signals so there is no cross talk.
When I say, talk to, I mean the devices put off signals, electrical surges, static, whatever, and the vehicle CPU might read this as a sensor on the vehicle and then do something odd like make minor engine adjustments.
