RV.Net Open Roads Forum: Tech Issues: Battle Born Lithium
 > Battle Born Lithium
Page of 6
obiwancanoli
Napa
Posted: 09/19/20 10:15am Link  |  Quote  |  Print  |  Notify Moderator
In my research to learn more about Lithium batteries, and replacing the flooded 6V's in my rig, I just discovered Battle Born Lithium Batteries (Reno, NV) will soon be introducing a 250Ah battery, due sometime later Fall, or early Winter... no pricing yet...
2oldman
The Q
Posted: 09/19/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Hard to find anything about that.. link?
near Jawbone Canyon, CA
Posted: 09/19/20 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Hopefully it’s dimensions will fit my TT tongue. 250 AHs with 200 + or - usable is more than enough for our needs
lryrob9301
Mid-Atlantic
Posted: 09/19/20 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Well if their 250AH is priced anything like their 100AH it will be around $1250 to $1500 per battery. I can sure buy a lot of lead acid batteries for what a couple or three of the lithium will cost. You would have to be a hard core boondocker for them to pay for themselves.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
2oldman
The Q
Posted: 09/19/20 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
It's not always about money.
theoldwizard1
SE MI
Posted: 09/19/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
Companies in China have been producing 200Ah and 280AH LiFePo4 cells for some time now. I don't know the exact physical size, but they are "similar" to the 100Ah cells.
If you are a DIY person, the pricing is actually very reasonable evevn when you add in the BMS.
bob_nestor
murphy
Posted: 09/19/20 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
It's all about life-cycle cost. When you factor in the life span of the Lithium-Ion vs the lead acid the cost comes out almost the same. (Also helps to factor in the power available for use - generally a smaller Ah Lithium-Ion will give the same usable power as a higher Ah lead acid.) However, if you not keeping your RV long enough to amortize the cost of the Lithium-Ion it becomes a moot point.
2oldman
The Q
Posted: 09/19/20 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Minus all the maintenance and the weight and replacing them.
Gdetrailer
PA
Posted: 09/19/20 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Nothing like believing smoke and mirrors..
Maintenance?
Once a year I simply add a few ounces of water per cell to my GC2s..
Never had to clean the terminals, you can EAT OFF THEM RIGHT NOW.
If you are cleaning terminals often the SEAL between the terminals and battery case have been damaged or you are BOILING your batteries to death (bad converter). My first set of GC2s I never once removed the terminals to clean and they were as bright as the day I had installed the batteries when I replaced them.
Life?
My first set of GC2s were 9 yrs when I replaced them, they were still doing OK and could have gotten a few yrs more out of them. The only reason I replaced is I use them heavily when traveling since they support my home fridge conversion and didn't want my fridge to run out of power while traveling.
Cost?
$80 each for $160 and 9 yrs of use..
For me to spend $1500 and only get at best 10 yrs out of Lith batteries pretty much describes insanity. The "jury" is out on just how long Lith batteries really last. From my experience with commercial products that used Lith batteries is don't hold your breath, some only lasted a couple of yrs..
I will pocket the money I didn't spend on Lith batteries for OTHER much more fun things.
* This post was edited 09/19/20 03:16pm by an administrator/moderator *
pianotuna
Regina, SK, Canada
Posted: 09/19/20 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
216 amp-hours SiO2 $999 usd. 4D
https://azimuthsolarproducts.com/product/12v-216ah-sio2-battery/
They have a 270 amp-hour unit as well.8D
* This post was edited 09/19/20 07:43pm by pianotuna *
Regards, Don
Page of 6
