RV.Net Open Roads Forum: Tech Issues: Battle Born Lithium
 > Battle Born Lithium
Page of 6
free radical
Canada
Posted: 09/19/20 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
obiwancanoli wrote:
In my research to learn more about Lithium batteries, and replacing the flooded 6V's in my rig, I just discovered Battle Born Lithium Batteries (Reno, NV) will soon be introducing a 250Ah battery, due sometime later Fall, or early Winter... no pricing yet...
Will Prowse dyi solar chanel has great info
https://youtu.be/gOqQp2Xjr6U
RickLight
Washington
Posted: 09/19/20 08:56pm Link  |  Quote  |  Print  |  Notify Moderator
Considering;
I spent under $2K for 315AH and a 75A charger.
Prowse is showing how to DIY a 100AH for under $500.
One BMS and less case should make the new BB much less expensive.
LiFePo has many other benefits than cost, and isn't as expensive as it used to be.
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
Durb
NW
Posted: 09/19/20 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
Hopefully it’s dimensions will fit my TT tongue. 250 AHs with 200 + or - usable is more than enough for our needs
If it is Battle Born, 250 ah will be useable. It is in their design parameters of their other batteries. That baby will be expensive; I hope you have a good battery lock box!
time2roll
Posted: 09/19/20 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
I would assume 250 ah would be size 8D
https://relionbattery.com/products/lithium/rb300
675w Solar pictures back up
BFL13
Victoria, BC
Posted: 09/19/20 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
If you run your MW off inverter drawing 130 amps for 10 minutes from that 300AH Li 8D, is that "continuous" and so over its 100 amp rating, or is that short enough time to be "peak" at the much higher amp rating, so you would be ok?
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Itinerant1
Itinerant
Posted: 09/20/20 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Relion doesn't show so probably would have to talk to someone to see if there an x amount of minutes.
If you look at this data sheet for Lifeblue 300ah battery you would have no problem running that load.
When buying dropins not all are created equal. Check out the small details to make sure it will fit your power wants.
12v 500ah (5,120Wh usable) , 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts) 2s4p. Panels mounted flat on the roof. Magnum PT100 controller, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365
deltabravo
Spokane, WA
Posted: 09/20/20 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Where was this discovery made?
I can't find any info about this.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
dieseltruckdriver
Black Hills of SD
Posted: 09/20/20 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I agree. I spend a good amount of time watching his reviews.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
time2roll
Posted: 09/20/20 08:58am Link  |  Quote  |  Print  |  Notify Moderator
That would be reason to have two in parallel or go 24v. I would not want to run it over the specs by design.
pianotuna
Regina, SK, Canada
Posted: 09/20/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I was under the impression that 1C was a "rule of thumb" with LI for current (amps). So a 300 amp-hour LI should laugh at a load of 130 amps continuous.
iirc the Battle Born can do 3C for five minutes.
Regards, Don
Page of 6
