RV.Net Open Roads Forum: Tech Issues: generator question
 > generator question
hud60
nebraska
Posted: 09/20/20 11:25am Link  |  Quote  |  Print  |  Notify Moderator
does anyone know if I can pair a 2021 onan gen. prepped 5th wheel with a Honda 6500 generator? could a knowlable electrician be able to do this?
CA Traveler
The Western States
Posted: 09/20/20 11:39am Link  |  Quote  |  Print  |  Notify Moderator
All kinds of gens are used to power RVs. My concerns would be exhaust, carrying gasoline, noise/vibration, everything else.
2014 Grand Cherokee Overland
Bob
pianotuna
Regina, SK, Canada
Posted: 09/20/20 11:40am Link  |  Quote  |  Print  |  Notify Moderator
May I ask what you are attempting to run?
* This post was edited 09/20/20 01:14pm by pianotuna *
Regards, Don
DrewE
Vermont
Posted: 09/20/20 12:57pm Link  |  Quote  |  Print  |  Notify Moderator
I'm assuming you don't have the Onan generator in the RV, just the prep package for a generator.
It should be entirely possible to wire in a connection for the Honda generator to the prep wiring. Fuel connections and physically installing the generator in the space are likely to be rather more difficult, and might be altogether impractical or impossible.
Note that the Honda EB6500 and EM6500 generators (in all their subvariants) are open-frame, contractor style generators and as such fairly loud. The EU7000IS is a quiet inverter generator, and would be much preferred, particularly if you're camping in proximity to other people.
If you have the Onan generator installed, paralleling it with a Honda generator won't work.
K Charles
Connecticut
Posted: 09/20/20 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
The manual for the Honda 6500 says to keep it 3 ft away from everything while it is running. How big is the spot where you want to install it?
2oldman
Mecca
Posted: 09/20/20 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Afaict those are not inverter gens. An electrician *may* be able to.. really don't know.
hud60
nebraska
Posted: 09/20/20 08:38pm Link  |  Quote  |  Print  |  Notify Moderator
hud60
nebraska
Posted: 09/20/20 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
the generator is an eu6500 very quiet. it stays in our pu box to use while traveling. it will not be installed in rv. just want to be able to control from rv while parked for the night
DrewE
Vermont
Posted: 09/20/20 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
I think you are in luck; the remote control connections for the Honda generator appear to me to likely be compatible with typical Onan controls, at least for the start and stop controls. The pilot light circuit may not be compatible. Your generator manual has a wiring diagram that includes the remote control connections for the start and stop controls.
2oldman
Mecca
Posted: 09/21/20 07:06am Link  |  Quote  |  Print  |  Notify Moderator
I'm not sure what the question is now.
