RV.Net Open Roads Forum: Travel Trailers: Undercarriage Storage
 > Undercarriage Storage
SoManyRoads13
Wheat ridge, co
Posted: 09/20/20 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
Hey All,
Quick question:
I have a 1990 KIT Road Ranger Espre that I have been updating. I am wondering if y'all think it's advisable to attach a ceiling storage rack that one would find in someone's garage underneath my trailer. There's a solid amount of ground clearance and the storage rack that I'm looking at only has only 12" of drop. I'm more concerned with the lag screws going into the underbelly of the trailer and whether the underside would be able to support the 80lbs rack and whatever I throw onto of it. The undercarriage is covered in a weather resistant plastic and I believe that there is plywood above that.
I'm interested to see the replies here.
Thanks.
jdc1
Rescue, Ca
Posted: 09/20/20 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
Attached to the frame? Why not?
profdant139
Posted: 09/21/20 04:46am Link  |  Quote  |  Print  |  Notify Moderator
Instead of lag screws, maybe use self tapping screws that go into the metal chassis, rather than into the plywood underbelly?
Are these closed shelves? What are you planning to put on the shelves, and how are you going to keep the stuff clean, dry, and in place?
This sounds like a worthwhile project -- please post photos when it's done!
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
gbopp
The Keystone State
Posted: 09/21/20 04:54am Link  |  Quote  |  Print  |  Notify Moderator
The 80 lb. rack and whatever will greatly increase in weight when you go bouncing down the road.
Make sure it's fastened securely to the frame.
It sounds like a good idea if it's done right.
TenOC
On the road -- Full time
Posted: 09/21/20 07:09am Link  |  Quote  |  Print  |  Notify Moderator
I would use real bolts and nylock nuts with holes drilled in the flange of the I-beam. If you have a channel beam place a metal strap (home made U bolt) over the channel.
I have lost a stinky hose holder and hose when self-taping screws came out on a bumpy road.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
SoManyRoads13
Wheat ridge, co
Posted: 09/21/20 07:48am Link  |  Quote  |  Print  |  Notify Moderator
Right. Fastening to the frame sounds much better. I'll have to take some measurements to make sure that the proportions/dimensions work. Thanks for the hardware recommendations, TenOC.
profdan139: They are not closed shelves. I'm still figuring that out, maybe some thick vinyl? I would keep my little giant ladder down there and Rubbermaid bins of whatever else. I would use rachet staps for the bins and u bolt bike locks to secure the ladder in place.
BarneyS
S.E. Lower Michigan
Posted: 09/21/20 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Have you seen these Lippert underchassis storage systems?
Might be worth a look instead of re-inventing the wheel. [emoticon]
Barney
* This post was edited 09/21/20 09:31am by BarneyS *
Not towing now.
SoManyRoads13
Wheat ridge, co
Posted: 09/21/20 09:55am Link  |  Quote  |  Print  |  Notify Moderator
I have. I could get much more storage for less than half the cost.
harmonmonic
San Francisco
Posted: 09/23/20 07:05am Link  |  Quote  |  Print  |  Notify Moderator
BarneyS wrote:
Have you seen these ***Link Removed***
Barney
Thanks, nice store. Exactly what i need
