RV.Net Open Roads Forum: Class A Motorhomes: Chassis clarification
 > Chassis clarification
Procrastinator
Southern Illinois
Posted: 09/21/20 11:02am Link  |  Quote  |  Print  |  Notify Moderator
We are in the real early research stages of our first motorhome after 20 years of various trailers.
We really want a shorter motorhome and I have been studying Class B+ and Class C's for that reason.
I feel that I have read, or maybe misunderstood that some of the shorter class A's are built on Ford's E450 frames.
If that is correct, does anyone know how I can search for those models or manufacturers?
Thank you in advance.
2018 F150 Max Tow with 6.5 "long" bed.
2019 Coachman Freedom Express Liberty 292BHDSLE
MountainAir05
New Mexico
Posted: 09/21/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
No help here but what length are you looking at.
What brand name or features are you wanting. Those features along with length will determine on what frame you will get.
Smitty77
OnDRoad
Posted: 09/21/20 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Class A's Ford are usually on the F-53 chassis. Class C's are on the E350 or E450.
The shorter F53 Class A's are usually on a 18K LB's chassis. And then as you go up in length, and or quality, the chassis ratings go up to a high as 26K LB's.
One tip besides rating, is to factor the chassis wheel base length, in relation to coach length. Many of the entry level Class A's are on shorter wheel base's - which result in quite bit of tail hangover. Tail hangover can impact drivability, and dragging onto the ground at places... The term Tail Wagging the Dawg comes to mind, in heavier winds, as as Semi's blow by on the Interstates...
Best of luck on your search,
Smitty
way2roll
Wilmington NC
Posted: 09/21/20 11:40am Link  |  Quote  |  Print  |  Notify Moderator
in recent years, I believe the Thor axis/vegas are the only Class A's built on the E450. All the rest of the gassers are on the F53.
2020 FR Cedar Ridge Silverback 29rw
IAMICHABOD
Sunny So Cal 90713
Posted: 09/21/20 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
This topic has been discussed on the Thor Forum It may be of help to you.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
crasster
Dallas
Posted: 09/21/20 04:50pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah most likely they'll be built on Ford/Chevy 350 450 3500 4500. Seen some Mercedes.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Yankee Clipper
Cairo, GA
Posted: 09/21/20 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
Shorter rigs are problematic, as the manufacturers seem to view them as low-cost entry level motorhomes. You may be better served by a bigger used rig. After a couple of years,most of the depreciation has been taken, and the bugs mostly worked out. We have been the third owners of both our Class A rigs, and we have had pretty good luck with the integrity of the chassis and interior repairs the prior owners dealt with. JMHO.
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, Duke the overgrown Boxer mascot/lousy watch dog
Rosey the minidachshund resident Princess-in-Chief
Procrastinator
Southern Illinois
Posted: 09/25/20 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I just wanted to say thank you for the responses and the resources.
Pro
