RV.Net Open Roads Forum: Tow Vehicles: 2020 chevy equinox LT
Search only in Tow Vehicles
 > 2020 chevy equinox LT
dreamrver
St. Louis, MO
Posted: 09/22/20 08:01am Link  |  Quote  |  Print  |  Notify Moderator
does anyone have one and tow it 4-down does it to do good i am thinking of buying one. thanks in advance
howdy35
Athens, Texas
Posted: 09/22/20 08:38am Link  |  Quote  |  Print  |  Notify Moderator
If you search "Chevy Equinox", you will find lots of information that is helpful. You might check with "Executive" I see he is towing a 2014 Equinox. Happy travels Arnold
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
Executive
Posted: 09/22/20 09:11am Link  |  Quote  |  Print  |  Notify Moderator
I bought mine new in 2014 and found it to be an excellent all around toad. That said, every toad has it's faults. Best toad I've had was the Chev HHR which is no longer made. The only difference though was the HHR had more interior room due to it's layout. The Equinox has been a trouble free vehicle with over 41,000 miles on the odometer and around 60,000 towed miles. We have the LTZ 4cyl model and I would get the 6cyl next time around because of the steering. The 4 has electronic steering and the 6 hydraulic. The 4 suffers from the 'death wobble' while the 6 does not. It's been solved with pulling a different fuse but you must add a charging module. ($49) so no biggie. For 2020 I believe they made some minor changes so you should look at the owner's manual to see what needs to be done to tow it four down. The body is the same. You might also look at the Blazer which looks great from the outside. I haven't spent any time at a dealer recently so I can't give you any info on them. I'd recommend the Equinox based on my success with it. Hook it up, put it in neutral, flip the switch and go....Dennis
Click HERE for the 2020 towing guide.
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
near Jawbone Canyon, CA
Posted: 09/22/20 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Have you confirmed with Chevrolet (not a dealer salesman) that the 2020 Equinox model you are viewing is four down towable?
BurbMan
Islip, Long Island
Posted: 09/22/20 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
Here is the 2020 Equinox Owner's Manual.
Page 346 tells you that all models can be towed 4-down, but Chevy advises starting and running the vehicle for 5 mins at each fuel stop and at the end of the day to ensure proper drivetrain lubrication.
Wasn't that easy?
2015 Ram 3500 4x4 Laramie Crew Cab Long Box, Cummins diesel
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Posted: 09/22/20 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
"Wasn't that easy?" Looking at the 2020 Chevrolet Trailering Guide, Burb, it isn't that easy.
See page 26...it says "yes" to the 2WD and "NO" to the all wheel drive. OP doesn't say if he is considering 2 or all wheel drive. Essential information to a response.
https://www.chevrolet.com/content/dam/chevrolet/na/us/english/index/vehicle-groups/trailering-and-towing/trucks/02-pdfs/2020-chevrolet-trailering-guide.pdf
FloridaRosebud
Melbourne
Posted: 09/22/20 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Wasn't that easy?
I have a GMC Acadia I flat tow, and the instructions are the same. No issues here.
Al
dreamrver
St. Louis, MO
Posted: 09/23/20 07:47am Link  |  Quote  |  Print  |  Notify Moderator
thanks for the replys i did google the info before i posted but i wanted personal experience. thanks dennis for all the info
gobigred
New Braunfels, Texas USA
Posted: 09/23/20 11:25am Link  |  Quote  |  Print  |  Notify Moderator
I have the 2018 Diesel Equinox. I tow it 4 down and it does fine EXCEPT you will need a charging line to the battery. The battery will run down otherwise and it is a real pain. The standard engine and transmission can also be towed 4 down. However the 2018 9 speed transmission was not approved for towing.
Retired in Texas
bikendan
Camano Island, Wash.
Posted: 09/24/20 02:59am Link  |  Quote  |  Print  |  Notify Moderator
should be moved to the Dinghy Towing section, since this section is for vehicles that tow.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
