Cummins12V98
on the road
larry barnhart wrote: Buying a new TT tomorrow. Endurance 15" tires. Only 2 sizes. One is 600 lbs higher capacity. Happy to not be China bombs. Will buy the higher load. Chevman
Right on!!!!!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
GY ENDURANCE, Stellar record. NUFF SAID.
As mentioned be sure your suspension is dialed in.
RobWNY
Jamestown, NY
shinkebein wrote: Our trailer weighs roughly 12,000 fully loaded and we drive 65 - 70 tops. They didn't mention replacing rims, only bearings and hubs.
How do you know your trailer weighs roughly 12,000 fully loaded? Have you taken it to a CAT scale or some other scale to have a good idea of the weight? How do you know you aren't way over weight?
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
Edd505
Elephant Butte, NM
Put on LT tires not ST, I have a 14K 5W and travel about 7o most of the time, zero issues. I have run LT tires on all my 5W's and do not have tire issues, just watch pressure. There have been good reports on some newer ST tires, Sailun and Goodyear 614s
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
tempforce
Oregun Pacific Wonderland (in the summers)
check the tread wear. is it flat, on the edges or only on one side. also I was plagued with blowouts until I went to rims rated for more than 65 psi, as having e rated tires at 90 psi was causing the rims to crack and leak. thus blowing a tire due to under inflation and heat. I would have the wheel bearings cleaned and repacked with high temp grease. new seals. every 2nd year. if any signs of wear shows, then replace the bearing and race. + seal. balance the tires. new valves wu=ith tires. I like metal stems... make sure the tire sidewall doesn't have a warning for speed. most trailer tires are only rated for 60-65 mph. (they used to be rated at 55 mph). using LT tires is a upgrade. just make sure they are rated for more weight than you are hauling. with a good safety margin..
somewhere in the texas 'lost pines'
currently without rv.
'13' Ford Fusion
'83' Ford Ranger with a 2.2 Diesel.
'56' Ford F100, 4.6 32 valve v8, crown vic front suspension.
downsizing from a 1 ton diesel and a 32' trailer, to a 19-21' trailer for the '56'.
Sjm9911
New Jersey
Just curious, when was the last time you checked, repacked the bearings?
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
garyp4951
TN
I would clean, and inspect the hubs, and do new Timken races, bearings, and seals if the hubs look ok.
phillyg
SWFL
Your first blowouts are not unexpected as the tires were old when you purchased the rig. GY Marathons have fallen out of favor over the years, and I don't think the GY Endurance makes your size. Sailun, although Chinese-made, has a stellar reputation. In fact, I've only heard of one failure, in multiple forums, and the reason was inconclusive. Lastly, there's no reason to replace bearings and hubs unless they already damaged. In some cases, its easier and cheaper to just replace the entire hub/race/bearing as a set.
Rvpapa
Alberta , Can.
You are towing level ?
Art
RVK
Virginia
The bottom line is nearly all trailer tires suck. I had two Marathons blow out within a couple of days. They were two years old with about 10K miles. The only ones I've not heard numerous complaints about are Maxxis and Sailun. Maybe some of the expensive, commercial type trailer tires from Goodyear, Michelin, and others. I'm running light truck tires on my 5th wheel now.
