RV.Net Open Roads Forum: Fifth-Wheels: Multiple blowouts in short time
 > Multiple blowouts in short time
Old-Biscuit
Verde Valley
Posted: 09/22/20 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
Lay straight edge across tires.
should make even contact at both sides of both tires
Check axle Upward Bow..... both axle should have same bow
Lay straight edge across bottom of axle tube centered
Measure distance from straight edge to axle tube...compare to other axle
US NAVY------USS Decatur DDG31
larry barnhart
wenatchee. wa usa
Posted: 09/22/20 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Buying a new TT tomorrow. Endurance 15" tires. Only 2 sizes. One is 600 lbs higher capacity. Happy to not be China bombs. Will buy the higher load. Chevman
chevman
2019 rockwood 34 ft fifth wheel
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
theoldwizard1
SE MI
Posted: 09/22/20 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Replacing bearings and hubs seems very odd ! You should never have to replace a hub unless a serious bearing failure. Bearings usually start running hot or making noise before a massive failure.
Switch to LT tires and make sure they can carry your load with room to spare.
rhagfo
Portland, OR
Posted: 09/22/20 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
shinkebein wrote:
Our trailer weighs roughly 12,000 fully loaded and we drive 65 - 70 tops. They didn't mention replacing rims, only bearings and hubs.
If you don't have an alignment issue, consider switching to LT truck tires, Yes the same tires on the TV!
We bought our 2005 Copper Canyon in 2012 with the original LT tires on it. I checked them and ran for another four years.
When we replaced we bought Yokohama YK-HTX 235/85-16E's these tires have a lower weight rating than ST tires, but a higher speed rating (Much Higher). These tire have a 3,042# rating, I carry a little over 10,000# on the trailer axles with the 5er at about 12,600#.
On Edit: Do you cover your tires when not towing??
Lantley
Ellicott City, Maryland
Posted: 09/22/20 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
My prior TT gave me all kinds of headaches with flats until I finally figured out the problem was a leaky rim. I ditched the OEM painted white rims and purchased 4 new aftermarket aluminum rims, problem finally solved.
The rims were cheap , the twisting and skidding forces the wheels endured when backing up and making a tight turn caused the rim to separate and leak.
I eventually sold those aftermarket rims to forum member Burbman when I sold thee TT and went to a 5th wheel
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
agesilaus
North Florida
Posted: 09/22/20 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
I went to LT tires and got rid of our Marathons ST tires. How often does your truck have a blowout after all and it uses LT tires.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
hawkhill
Posted: 09/22/20 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
I would recommend taking your trailer to a good truck alignment and axle shop in Houston. We had a similar problem with our tires and found RV dealers clueless. We are in Florida and are lucky enough to have a great truck frame and alignment shop in Orlando called Josam that does RVs as well. It was truly sad how poor our alignment was done out of the factory. Once our trailer was properly aligned, our issue with blowouts has disappeared. I hope I have not cursed myself by putting that statement in writing.
2015 RAM 3500 dually Deep Cherry Red Crystal 6.7 Cummins Aisin 6-Speed
2008 Carriage Cameo F35SB
Jeff "Loving DH"
Smokey & Purrshing, Our Ragdolls
Gordie, Springer Spaniel
True Blue, Aussie
NMDriver2
New Mexico
Posted: 09/22/20 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Summer time ST tires blowout. ST tires cannot handle heat. Go LT and drive without blowouts summer and winter--as long as the pressure is right [emoticon]
Turret Class traveler
Lynnmor
Red Lion
Posted: 09/22/20 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
They screw in six bolts.... done!
time2roll
Posted: 09/22/20 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
If the alignment was that bad I would expect a Bad wear pattern showing.
675w Solar pictures back up
