RV.Net Open Roads Forum: Truck Campers: Finaly got my new ARB locker!
 > Finaly got my new ARB locker!
KKELLER14K
BEAVERTON OREGON
Posted: 09/23/20 02:28am Link  |  Quote  |  Print  |  Notify Moderator
I was in the NW forest in snowy conditions with my AF1150 and being naive...thought that my 4x4 was just that...WOW was I wrong. I didn't know what the difference was between a full floating Dana 60 and locker really was. I'm not so smart right? I was stuck in a really bad place and my front end failed me. I swore I would never have it happen again. When I needed traction it failed, Horribly..badly, scary bad. So a new project has been on my bench.....I already have on board air...this is not the first time I have been in the front end...A total rebuild with Moog everything so I know that Dana 60 now!! The decision was to go with air or electronics. After a lot of mind bending...being the air was already there...OK so what is your take on it?...I wanted a true locker. I'm saying when you need it...you got it, both tires pulling..but it will still float in 4x4 going down the road unlocked.
* This post was edited 09/23/20 02:41am by KKELLER14K *
BurbMan
Islip, Long Island
Posted: 09/23/20 06:09am Link  |  Quote  |  Print  |  Notify Moderator
That's the right tool for the job if you're out in the rough stuff. I would opt for air if it's already onboard. What truck do you have?
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
jimh425
Western MT
Posted: 09/23/20 07:31am Link  |  Quote  |  Print  |  Notify Moderator
Congrats. Chaining up didn’t work?
Lone Pine, CA
Posted: 09/23/20 07:49am Link  |  Quote  |  Print  |  Notify Moderator
Any pictures to share?
noteven
Turtle Island
Posted: 09/23/20 08:02am Link  |  Quote  |  Print  |  Notify Moderator
My F-3 fitty has the factory electric rear locker for low speed three wheel drive. No locker in the front. It auto shifts to open diff as speed increases. I can't remember if it stays locked in if you are using low in the transfer case.
A driver controlled locking diff or two is handy as a shirt pocket. So is air on board for airing down and up.
If gravity can overcome traction in a dangerous manner I am not too proud to put chains on a truck.
deserteagle56
Nevada
Posted: 09/23/20 10:08am Link  |  Quote  |  Print  |  Notify Moderator
Tell us more about "my front end failed me". Was it because only one front tire was spinning? Or did you have automatic locking hubs, or an axle disconnect, that failed to work? Most front end "failures" are due to those two things. Manual locking hubs are the only way to go - seems like the auto ones always fail when you need them most. I had a GM with the axle disconnect that failed to engage when I got stuck in a snow bank.
I had ARBs installed front and rear in my van (E350). Made a world of difference in the rough stuff. Allows me to crawl through bad spots that previously I'd have had to tackle with speed.
1996 Bigfoot 2500 9.5 on a 2004 Dodge/Cummins dually
kohldad
Goose Creek, SC
Posted: 09/23/20 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Air operated are prone to leaks and you won't know you have a leak until it won't work.
Cable operated are very reliable but you have to run that cable just right for it to work and it could get snagged.
Electric operated are vey dependable, wires are easy to run in a protected way. This would be my choice.
Generally, the limited slip device goes in the rear first since that is where most of the weight is located. If you have a device in the rear, than the front makes sense. However, before I spent the money on a locker I would invest in a good winch for the front and then learn how to use it by praticing and taking a class if need be. Not only would the winch help you out more than a locker, but it will also benefit any others you run across.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Geo*Boy
Unknown
Posted: 09/23/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
What about a winch that can be used in the front or back of the truck to pull you out of a bad situation?
Freep
Wisconsin
Posted: 09/23/20 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Smarter than me. I have no idea what you're talking about.
[emoticon]
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
KKELLER14K
BEAVERTON OREGON
Posted: 09/23/20 04:14pm Link  |  Quote  |  Print  |  Notify Moderator
Check the profile but I have an 02 Dodge dually. With the floating front end on the Dodge there is no locking hubs. So the quick story is I'm on a snow covered road that pitches to one side....the front starts to slide down hill and as I try to turn back up hill, the front will spin only one tire. My mistake not having chains, which of course I carry always now was a learning curve. I had to use tree limbs to get the front to pull me back straight. I don't have a winch setup "yet" that is on the list but I will have the full pull If it was to happen again. I'm learning as I go but to me I think it will be a fun thing to install and it is an insurance that both tires are pulling when I need it... it will be there.
