RV.Net Open Roads Forum: Fifth-Wheels: New tires for my 16K fifth wheel
 > New tires for my 16K fifth wheel
MarkTwain
Northern, Ca. , USA
Posted: 09/23/20 02:31pm Link  |  Print  |  Notify Moderator
howardwheeler wrote:
I just checked my current Goodyear G614 RST tires for age and they are five and a half years old. They are load range G LT235/85/R16. This is the first set I’ve ever NOT had a blowout on. Basically trouble free. First question, should I age them out at five years? Second question, though these Goodyear’s have finally been good tires with zero problems, are there any recommendations as to a better choice? I am most concerned with no blowouts. I’ve had my share of experiences and don’t want any more. I am fastidious with air pressure and keep my TST TPMS active at all times when towing. What do you think is the best choice if indeed I should age out at five years. Thanks for any recommendations. I am okay with replacing these with the identical tire since finally I’m getting good service from a tire. I have relatively new HiSpec rims and don’t want to move to a 17.5 rim because of expense. Again, thanks for any thoughts.
Have always used the G614 LT 16 in. Tires. I use them for 5-7 years depending on their condition. At 7 years I replace them all. I use metal stems including the spare. Never had one flat tire??????
howardwheeler
West, Texas
Posted: 09/23/20 02:44pm Link  |  Print  |  Notify Moderator
This set is at five and half years and I’ve not had one problem with them—unlike all previous load G tires, including Goodyear’s.
* This post was edited 09/25/20 09:40am by howardwheeler *
MFL
Midwest
Posted: 09/23/20 03:21pm Link  |  Print  |  Notify Moderator
This set is at give and half years and I’ve not had one problem with them—unlike all previous load G tires, including Goodyear’s.
You said you will take long trips, when you do go. You are saying you had previous problems with GYs, just not the current ones. With this information, I would definitely get the Sailuns others are recommending. May as well do it sooner, rather than later. Like Rob mentioned, piece of mind!
Jerry
Cummins12V98
on the road
Posted: 09/23/20 05:00pm Link  |  Print  |  Notify Moderator
The GY “G” tire as you already know is a great tire. Personally I would run then to 7 years.
GY did have a bad run of those tires but that was 13 years ago and since they have been a great tire.
* This post was edited 09/24/20 11:32am by an administrator/moderator *
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
cummins2014
Utah
Posted: 09/24/20 06:31pm Link  |  Print  |  Notify Moderator
Some have voiced their opinion on Sailuns . All I can add is if you want the best G or H rated tire on the market , that would be Saliun S637’s .It’s been proven for several years now , and the best thing about them is they are nearly half the price of the Goodyear’s . Or just settle for second best , and spend nearly twice as much .
* This post was edited 09/24/20 06:56pm by cummins2014 *
blofgren
Surrey, B.C.
Posted: 09/24/20 07:11pm Link  |  Print  |  Notify Moderator
x2. I've had mine for going on 6 years now and they still look like new. I would not hesitate to buy them again.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
Edd505
Elephant Butte, NM
Posted: 09/24/20 08:06pm Link  |  Print  |  Notify Moderator
Lwiddis wrote:
After perfect service why would you search for something else?
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
cummins2014
Utah
Posted: 09/24/20 08:59pm Link  |  Print  |  Notify Moderator
Well for starters nothings perfect , but there is better , and better weight ratings . Sailun is that tire .
mtofell1
Oregon
Posted: 09/24/20 11:47pm Link  |  Print  |  Notify Moderator
Replace them.... lot's of failures start around the 5/6 year mark. A friend I camp with each year tried to push it and had 2 blowouts within a couple weeks on 6 year old tires. Got me to go replace my 4.5 year old ones. It's just not worth the potential problems. Rolling around on new rubber feels great.
cummins2014
Utah
Posted: 09/25/20 08:35am Link  |  Print  |  Notify Moderator
4.5 seems a bit soon, but 5-6 has worked for me. Especially the Sailuns . I think 7 was mentioned ,thats taking a big chance .
