RV.Net Open Roads Forum: Truck Campers: Sewer hose?
 > Sewer hose?
BurbMan
Islip, Long Island
Posted: 09/23/20 11:32am Link  |  Quote  |  Print  |  Notify Moderator
I'm reinstalling the sewer hose storage on the Lance, which is just a 4" PVC tube with a hatch on the end. I used to carry 2-10' sections of hose in the TT bumper...most of the time 10' would do it but every once in a while you couldn't get close enough to the dump drain...
I tried to get a 10' section into the storage tube and only half of it would fit...do you guys only carry a 5' dump hose? seems awfully short. Is there a brand of hose where a 10' section collapses to a shorter length? Or are there other places to store the hose?
2015 Ram 3500 4x4 Laramie Crew Cab Long Box, Cummins diesel
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Kayteg1
California > Nevada
Posted: 09/23/20 11:48am Link  |  Quote  |  Print  |  Notify Moderator
20' of my "stinky slinky" collapse to about 3 ft for storage
I still carry "sewer solution" as my favorite way for hookup.
kohldad
Goose Creek, SC
Posted: 09/23/20 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
I use to carry an 5' hose which just squeezed into the compartment. Then I looked and noticed there was just enough room to mount a sewer hose carrier across the back of the camper. Now I can carry a single 10' hose which has worked every place I've stopped. Occasionally we stretch it real tight so my wife has to hold the one end in the dump while I pull the valves, but otherwise no issues.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
jimh425
Western MT
Posted: 09/23/20 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I use the Valterra 15 ft one. It’s heavy duty and collapses and stays collapsed.
Edd505
Elephant Butte, NM
Posted: 09/23/20 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Rhino Hose collapses, two fit in the standard RV rear bumper.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Sjm9911
New Jersey
Posted: 09/23/20 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
If the pipe goes the with of the camper ( most do) and your only getting 5 foot of waste hose in, something is wrong. Is it binding up or is something else in there? How did you mount it? Is it hitting a screw?
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
JimK-NY
NY
Posted: 09/23/20 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
I gave up storing a dump hose in a compartment years ago. The designated one was a rear bumper compartment that totally sealed. It was a tight fit and it made no sense to me to put a wet hose into a sealed compartment. On top of that the hose could never really be totally cleaned so it would stink when sealed up.
Instead I put an eye hook on each side of the camper under the bumper and behind the step. I use cord with snap fasteners to suspend the hose under the camper exposed to the air. The same hose has survived in that position for 10 years and 100K miles. Since the hose collapsed into a relatively small length, I would think I could fit two 10' hoses. If not I would just use a couple more eye hooks and another cord.
kohldad
Goose Creek, SC
Posted: 09/23/20 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Lance truck camper compartment is in the rear and only about 20" deep. I have the same itty bitty compartment on mine so know what the author is talking about.
cavie
Posted: 09/23/20 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
every sewer hose I have seen will collapse to about 3'. better get a flashlight out.
Sjm9911
New Jersey
Posted: 09/23/20 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Ah, thought he was mounting one somewhere. Didnt know it was in a compartment.
 > Sewer hose?
