RV.Net Open Roads Forum: Technology Corner: Need New TV
 > Need New TV
MURPHY55347
Savage, MINNESOTA
Posted: 09/24/20 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Beware newer Visio TV’s do not have a built in tuner so no over the air capability.
MrWizard
Traveling
Posted: 09/24/20 11:31am Link  |  Quote  |  Print  |  Notify Moderator
A TV ? Without a tuner is Not A TV
It is only a Display , a monitor
Technically to be a television it has to be able to receive broadcasts
AFAIK Vizio makes both types, as do many other mfg
Radiate The Happy
1997 F53 Bounder 36s
MURPHY55347
Savage, MINNESOTA
Posted: 09/24/20 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with your assessment. Vizio P, M, and most E series have no tuners. Some model E and all series D have tuners.
Wherever I happen to park
Posted: 09/24/20 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
If they do not have a Built in Tuner then they are called Monitors. NOT Televisions.
By Federal mandate a TELEVISION sold in the USA after I think 2007 must have a ATSC tuner/decoder in it.. Most Televisions sold in the USA This Century or the decade preceding have QAM decoders (Digital cable) but and most can get NTSC (analog) but by law newer than 2007 (I think) have to do ATSC (modern over the air digital)>
ELEMENT TV has ATSC. and far as I know NTSC but not QAM. It's the only one that I know of that does not have QAM.
And yes I know what all those letters stand for (Quadrature Amplitude Modulation for QAM And National/American Television Standards Committee for the others)
Used to be I knew how to fix em. today.. generally not worth it.
Home is where I park it.
coolmom42
Middle Tennessee
Posted: 09/24/20 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
I would opt for a Roku device over the built-in apps on a TV. I've had both, and the Roku apps work MUCH better and get updated more often. You also have a ton more choices.
All you need to use a Roku is a HDMI port. If the TV has a powered USB, you can use that for the Roku power. Otherwise, the Roku needs a separate USB adapter for its power.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
coolmom42
Middle Tennessee
Posted: 09/24/20 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Depends on the size, mostly.
IME smaller ones don't have tuners, but are great with devices like a Roku or Chromecast.
coolmom42
Middle Tennessee
Posted: 09/24/20 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Some of them do.
If it's called a TV it has a tuner. If it's called a monitor/display, it does not have a tuner.
2oldman
Mecca
Posted: 09/29/20 06:29am Link  |  Quote  |  Print  |  Notify Moderator
We hope these suggestions have been helpful, OP.
TechWriter
On The Road
Posted: 09/29/20 11:55am Link  |  Quote  |  Print  |  Notify Moderator
riltri wrote:
I have never replaced a tv in an RV. Any reason that a standard tv will not work?
If your new TV doesn't have a QAM tuner (sometimes called a "digital tuner"), then you won't be able to see TV programs coming from campgrounds with digital cable.
All new TVs must have OTA digital tuners (ATSC), but they aren't required to have QAM tuners.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
Posted: 10/05/20 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
Regarding TV/Tuner.. I once set up a video PAGING service for an event. Several televisions all fed by a RF driver fed by a VIC-20. During set up we were playing "The Loan Ranger" rebrodcast from a local TV station.. (Kind of good for a Vic-20 don't you think)
Actually the RF modulator was a VCR.
 > Need New TV
