RV.Net Open Roads Forum: Travel Trailers: Fresh water problem
 > Fresh water problem
Bobbo
Wherever I park
Posted: 09/29/20 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
StirCrazy wrote:
how are you sanatizing,just putting it the city water conection or putting it in the tank fill? Are you runing off your fresh water tank or are you hooking up to city water when it smells?
I had it when I was hooked up to city water it would taste/smell funny but when I used the onboard tank it would be fine. my sanatize process was using the fresh water tank as the source so it never got that bit bettween the city atachment and the water pump , so now I sanatize both ways.
Steve
After filling all of the lines with the bleach solution, open a faucet to relieve all of the pressure. Then, and only then, go around and push on the button in the middle of the shore water inlet and bleach water will backflow out of it so it gets sanitized too. BE SURE THE PRESSURE IS RELIEVED FIRST OR YOU WILL DAMAGE THE BACKFLOW PREVENTER!
Bobbo and Lin
kellem
Shenandoah valley,VA
Posted: 09/29/20 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
The city water hookup is such a tiny minuscule section of line, can't imagine the need to sanitize or the cause of any unpleasant odors. Idk
StirCrazy
Kamloops, BC, Canada
Posted: 09/30/20 06:18am Link  |  Quote  |  Print  |  Notify Moderator
neither could I, but on mine it did.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
StirCrazy
Posted: 09/30/20 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Steve
what button are you talking about? I am not sure even if i have this button how it would back flow up hill.
Steve
Bobbo
Wherever I park
Posted: 09/30/20 06:32am Link  |  Quote  |  Print  |  Notify Moderator
Without being there to point, I don't know how to tell you other than the button is in the middle of the backflow preventer. As far as water flowing uphill, I doubt that the shore water inlet is higher than the showerhead. Open the showerhead valve to vent the pipes, and water will backflow. My kitchen faucet is higher than my shore water inlet, so I can open my kitchen faucet for that.
(That is also how I get RV antifreeze into that section of piping.)
ksg5000
Oregon
Posted: 09/30/20 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
If it smells when you fill up at home and not when you use other sources then you know what the issue is.
Kevin
Posted: 09/30/20 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Miss Sunshine wrote:
I don’t trust that it’s safe to wash dishes. I’ll sanitize again when I get home.
Might just want to find a safe space if this is concerning to you?
Bobbo
Wherever I park
Posted: 09/30/20 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
I told the OP that back on page 2:
Bobbo wrote:
If the water from the campground "seems ok" but the water from your well doesn't, you have your answer.
That is apparently not what he wants to hear.
