RV.Net Open Roads Forum: Technology Corner: WiFi
Barry J
Massachusetts
Posted: 09/23/20 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
We are in a campground that has crappy WiFi. Our park model stays at this campground. What would you recommend for a WiFi booster that we can use to increase the strength of the WiFi.
Thank you Barry
Monterey, California
Posted: 09/23/20 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
Signal strength is the issue, or bandwidth?
See https://blog.goodsam.com/campground-wi-fi-getting-a-signal/
fj12ryder
Platte City, MO
Posted: 09/23/20 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Boosting the wifi signal does no good if the wifi is slow to begin with. It will allow you to connect better, but will not speed up a mediocre wifi. So make sure the wifi is worth boosting before you spend money to do so.
Howard and Peggy
"Don't Panic"
Thunder Mountain
Lost in the Four Corners
Posted: 09/23/20 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
The strength of the WiFi signal is not your problem. The bandwidth of the campground's connection is. There are just too many pigs at the trough trying to check email, surf the Internet and stream video. I know of very few campgrounds with useable WiFi. Check into using your smart phone as a hotspot.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
lap527
Ocala, Florida
Posted: 09/23/20 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
We just had fiber optics installed at our seasonal site in NC. The slow internet speed was a killer and we stream alot. So frustrating as someone said too many pigs at the trough. LOL! Now we only have one hog...and it pays the bill. We also can put it on vacay mode for up to 6 months. I don't know if that is an option but to us it's worth it.
2006 Dodge 3500 dually 4X4 / 2013 Livin Lite 10.0 TC /Torklift talons, fastguns, stableloads, superhitch, and truss/ towing a
14'V Nose Trailer when needed.
time2roll
Posted: 09/23/20 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
You probably need a cellular hot spot.
Although sometimes you may have some luck in the clubhouse. Ask where the antenna is.
675w Solar pictures back up
RickLight
Washington
Posted: 09/23/20 07:57pm Link  |  Quote  |  Print  |  Notify Moderator
The experts are at
https://www.rvmobileinternet.com/
Rick,
2019 Grand Design Reflection 150 273MK
2015 Ford F350 CC SB Lariat Powerstroke
PullRite Superglide
travisc
Pacific NW
Posted: 09/23/20 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Campground WiFi is throttled so you can’t used it like you own it, it a convenience for travelers for basic connectivity, if you want real internet get your own service
Winnebago Access 24V
Posted: 09/24/20 04:54am Link  |  Quote  |  Print  |  Notify Moderator
If it is a park model this means it does not often move. XIFINITY is blathereing about a 30/month gigibit plan Get park's permiossion to put it in .
Be nice, share (use a router with a guest connection)
Option 2 is a Jet Pack or Mi-Fi Cellular device. if you have a good Cell connection.. FMCA Tech Connect (SPRINT now merged with T-Mobile legally but towers are still different) 50/month+50 one time unlimited I've hit 100Mbps but not often.
Check speed before you buy
AllegroD
Outdare
Posted: 09/24/20 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
If you are using the internal (wifi)air card, it may be your location. The internal aircards are usually very weak, so they do not reach back to the source. Do others near you have the same problem? If not, you may need an external repeater or router to boost relay the signal.
