RV.Net Open Roads Forum: Truck Campers: rodent repellent
 > rodent repellent
Mike and Terry Ann
Trout run, pa
Posted: 09/24/20 09:10am Link  |  Quote  |  Print  |  Notify Moderator
Used uncle Gus pestproof in camper
Freep
Wisconsin
Posted: 09/24/20 09:59am Link  |  Quote  |  Print  |  Notify Moderator
We had pack rat move into our truck during our last extended camping trip. I cleared out the nest, which had a small rodent mummy the rat was keeping for some reason, and opened the hood for a couple of days. The good thing about an open hood is it's a great place to hang a hummingbird feeder.
Anyway, we drove into Laramie to dump and restock and my wife wanted me to look between the sidewall and the camper to see if there was any water(we had an intermittent leak) and I saw the rat. So I started taking off the turnbuckles and my wife started the jacks. This threw me off because it's not my usual routine so I jumped into high gear to get the turnbuckles off before she got too far with the jacks.
I missed a turnbuckle and the camper only came up part of the way. I panicked and went to open the turnbuckle but my wife stopped me before I got hurt and I lowered the camper back down undid the turnbuckle and then raised the camper again.
I pulled forward about halfway to take a look and the rat was passed out in the truck bed. Screwing up the turnbuckle actually worked in my favor because the rat got a little crushed when I lowered the camper. He surely would have found another spot to hide under the bed once I removed the camper. I used a turnbuckle to sweep him out of the bed and he woke up, but he was pretty badly injured and couldn't move quickly. I finally got him on the pavement and my wife attempted to put him in a bag and take him elsewhere.
All the while a truck with a couple of people were watching this hearing my wife scream a couple of times when the rat moved toward her. It must have been quite entertaining because they didn't leave until it was all over.
Now I always open the hood when camping in pack rat country and I will make sure I have moth balls between the camper and the truck.
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
midnightsadie
ohio
Posted: 09/24/20 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
guys right, fresh cab is pricy so I make up a bunch of little packs using old panty hose. put them every where. and peppermint oil. P.S some auto wiring was made with soy oil thats why they chew the wires.
Kayteg1
California > Nevada
Posted: 09/24/20 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
That's what works for me.
[image]Click For Full-Size Image.
1jogger
Southern Cal
Posted: 09/27/20 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Hard working jack russels!
We had 2 jacks that tore the wiring out from underneath
my F-350, they were really proud--$800.
Years later, a new ram we now keep it away from dogs with hood propped open 12"all day and low watt bulb underneath engine at night.
That was after $2000 wiring damage, luckily ins. helped.
Also sprayed "bitter apple" on all connections. This is used as deterrant for puppy chewing and it'll stay on surfaces for weeks.
No problems since, been 6 months.
Bert the Welder
Van. Island
Posted: 09/30/20 10:07am Link  |  Quote  |  Print  |  Notify Moderator
My wife's Audi got chewed up couple/few years ago. Had dealer install an ultrasonic box. Zero issues since. Good, as it's always on and always with you. No forgetting to turn something on/off or being SOL if you forget it/ can't plug in when camping.
"> 1998 GMC 2500, 10.5 Okanagan, My better/smarter half, George and Finnegan(APBT), all I need.
JRJR
Where there's fish
Posted: 10/13/20 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
An old sock with a bunch of mothballs in it is supposed to keep them out.
Sjm9911
New Jersey
Posted: 10/13/20 05:38pm Link  |  Quote  |  Print  |  Notify Moderator
I second the posion blocks. Set them in the hard rat or mouse traps if you have other animals. Freash cab / moth balls / irish spring people say work also.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
specta
utah
Posted: 10/13/20 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Kenny
2011 Chevy 2500 HD 6.0L 4wd
6580 lb truck 10540 fully loaded
rhagfo
Portland, OR
Posted: 10/13/20 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
rhagfo wrote:
Janss wrote:
We've tried several things to deter rodents. The only thing that has worked consistently and completely is putting a shop light under the hood. I plug it in with an extension cord over to my carport and a dusk to dawn timer. When we are on an RV road trip, we leave one car in the carport. I do the same thing for it, but I just lay the shop light on the ground under the engine.
I took this one step further, I installed a strip of cut to length LED lights around the inside of the engine compartment. The plug is on the right side of the bumper, and plug in ever time I get out of the truck.
Well I didn't have access to photos when I posted this, a drop light is a bit of a pain as you need to remove anytime you drive the truck. This is a permanent install with plug on drivers side of bumper.
Light shining under hood.
With hood open!
 > rodent repellent
