RV.Net Open Roads Forum: Class A Motorhomes: black tank flush port
 > black tank flush port
andybren
new jersey
Posted: 09/23/20 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2008 coachman Pathfinder diesel pusher which has a hose connection in the wet bay for a black tank flush. My question is ; do my other valves in the wet bay need to be in a particular configuration for the water to actually get into the black tank and do its job? No information is posted in the bay other than the one that says to open black tank drain before turning on the water.
navigator2346
texas
Posted: 09/23/20 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
The black tank sprayer is totally independent of anything else in the bay. From the female hose connector, there should be a back flow preventer valve and then pipe to the sprayer. It is wise to open the black valve just in case you forget you are flushing the tank to keep it from overflowing
Edd505
Elephant Butte, NM
Posted: 09/23/20 09:37pm Link  |  Quote  |  Print  |  Notify Moderator
You can close the valve while flushing, you will put approx 5 gallons a minute into the tank. Open & refill as needed until the tank waters running clear. DO NOT GET DISTRACTED, that can lead to serious damage. Keep the black closed except dumping or flushing.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Old-Biscuit
Verde Valley
Posted: 09/23/20 11:23pm Link  |  Quote  |  Print  |  Notify Moderator
If you haven't used it you should fist locate the Anti-Siphon Backflow Preventer device
It is installed at least 2' above black tank...typically inside bathroom sink cabinet
It acts like a check valve when water supply is turned off...allows air to enter tank side line so water drains back into tank
When water supply is ON the disc is pushed up blocking the air inlets
If it doesn't seal off...water POURS out and can flood bathroom etc
Water supply goes in bottom connection and flows to tank nozzle out the side connection
Someone should watch it when first using to make sure it doesn't leak
Cheap plastic ones are typical...better brass ones are available
Wherever I happen to park
Posted: 09/24/20 05:06am Link  |  Quote  |  Print  |  Notify Moderator
As the first reply said the tank flush line is 100% independent of all other plumbing. And in fact I suggest even using a different hose to feed it. and when not pushing water into the tank DISCONNECT it.
There are safety devices to prevent backflow from Tank to the water system. Mine has both a spring check valve at the tank and a vacuum breaker above the tank... BUT even with Belt and suspenders you can lose your trousers. (Thus I "Air gap" the line to insure no possible backflow.
Home is where I park it.
Executive
Posted: 09/24/20 11:09am Link  |  Quote  |  Print  |  Notify Moderator
I forgot mine once and had water coming out of the roof vent. 2 hours later after washing the coach and surrounding area, I vowed never to forget to open the valve while flushing...Dennis
A Simple Act of Caring Creates an Endless Ripple
Dennis and Debi Eleven Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
way2roll
Wilmington NC
Posted: 09/24/20 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I literally have a brown colored hose for the black tank flush. That's all it's used for.
2020 FR Cedar Ridge Silverback 29rw
