RV.Net Open Roads Forum: Tech Issues: Surge protector
 > Surge protector
jjrbus
FT Myers FL
Posted: 09/24/20 03:39am Link  |  Quote  |  Print  |  Notify Moderator
Reading a post on choosing between TPMS and surge protector. I only monitor my duals with a cheap TPMS and quite happy with it.
Have not looked into this but thinking why cant I add a whole house surge protector to my electric panel? I have a 30 amp RV. Mostly use a Honda 2000 for power, but always hooked up to house power at home.
Wherever I happen to park
Posted: 09/24/20 05:03am Link  |  Quote  |  Print  |  Notify Moderator
First there are two types of "Whole House" surge protectors (I have both) one is basically MOV's same as in those cheap "Power strip/Surge Protectors" and for RVers I do not recommend them for protection.. Oh they do work for what they are designed for which is spike supression but a good device like say a Progressive Industries HW-30C (hard wired so you don't forget it) or TRC equivlent or even one of the top end portables do so much more.
Spike supression.. like the little outlet box size job I have. A Given.
Power fail/restore timer.. Over 2 minutes of delay from power restore. When power BLINKS (Goes out for like 1 second) A/C's get tore up a bit as the compressor tries to restart with a full head of pressure... This means power in the CG is doing a bit of a roller coaster ride as they kick on and off. the Delay not only avoids the voltage ride. but lets the compressor bleed back to a normal start This is a MAJOR benefit.
Over/under voltage.. The Spike Supressor jobs .. Well I had about a dozen power strips in my basement when the power company restored power.. and goofed.. Hit me with at least double voltage.. Sounded a tad like July 4 with all the MOV - Fire crackers going off.. NO protection left and I lost a few things like the blower motor on my furnace and my computer's power supply.
Plug into 240 volts just once and the HW-30C paid for itself
They also protect if you have open neutral ground or other wiring mistakes.
They also protect against LOW voltage which damages mostly Air Conditioners.
I have the Southwire/TRC 50 amp hard wired here.. It works.
Home is where I park it.
deltabravo
Spokane, WA
Posted: 09/24/20 06:25am Link  |  Quote  |  Print  |  Notify Moderator
I use this one Progressive Industries SSP-30XL
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
Bobbo
Wherever I park
Posted: 09/24/20 07:32am Link  |  Quote  |  Print  |  Notify Moderator
I prefer the hard wired EMS HW-30C, myself. You can't leave it off because you are in a hurry or the weather is bad so you don't bother getting it out. Also, it can't walk off. Mine is currently (pun pun) on its second RV and 13th year.
Bobbo and Lin
WNYBob
Tonawanda, NY
Posted: 09/24/20 07:45am Link  |  Quote  |  Print  |  Notify Moderator
There is an issue when using a Generator! You will need a special wired adapter to use with a generator!
Make sure you do not get an Open Ground indication, you will need a floating ground plug.
You should be looking at an EMS (Electrical Management System) which does a lot more than simple Surge protector. Yes, they are more expensive, but the value if your electrical system/components is very high.
WNYBob
Tonawanda, NY
Posted: 09/24/20 07:54am Link  |  Quote  |  Print  |  Notify Moderator
Search " Portable Generator open ground " here an rv.net. You should get many hits on what to do.
2naEagle
McCalla, AL
Posted: 09/24/20 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Got this off another forum post. Good information about the subject.
Complete Guide to RV surge protection
EMS vs Surge Suppressor
2020 F350 Limited CCSB SRW
2017 North Point 315RLTS
2021 Jayco Redhawk 24B
Bobbo
Wherever I park
Posted: 09/24/20 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Not all generators. My previous RV had an ONAN Microquiet 4000 watt and it had the ground and neutral bonded. My EMS didn't have a problem with it. It wasn't until I traded RV's and bought a TT and a Honda EU2000i that I finally had to make a bonding plug. (Bonding plug was less than $2 to make. A trip to a big box hardware store for a replacement 3 prong plug plus an inch and a half of wire that was sitting around my shop.) You definitely want the open ground indicator.
* This post was edited 09/25/20 07:08am by Bobbo *
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 09/24/20 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
48 Volts 96 volts 240vac
Over or Under (40% error)
120vac 240vac output
with the 40% model
jjrbus
FT Myers FL
Posted: 09/26/20 05:38am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input, I will do some reading and decide what to do.
 > Surge protector
