RV.Net Open Roads Forum: Travel Trailers: TPMP High Temp Setting
 > TPMP High Temp Setting
Raife
Posted: 09/24/20 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hey everyone, hoping someone can help me out. I purchased a TST 507 TPMS system for my Grand Design Imagine XLS 21BHE and am trying to set it up. My tires are Westlake ST205/75R14 105/101L (yes I have read the threads on Westlakes so I don't need any comments there) and the cold tire pressure is 65PSI.
I set the low pressure warning at 10% below, 59PSI, per their recommendation but am having trouble setting the high pressure warning to 25% above, 81PSI, per their recommendation. The unit won't go below 100PSI. I know I am missing something. I tried to find the temperature ratings for the tire but there was nothing on the Westlake website.
How do I know what to set the high pressure limit at?
Thank you.
* This post was edited 09/24/20 09:02pm by Raife *
Bobbo
Wherever I park
Posted: 09/24/20 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
It has been a while (a long while) since I set mine and my memory is fuzzy, but, as best I recall, I had to skip whichever setting came up first and set the second one. Then I could go back and set the first one. The temperature, I left at factory setting. (Even at factory setting it saved me from an RV fire a few years ago when a brake started dragging. When it alarmed and I got pulled over, the wheel was smoking.)
Bobbo and Lin
Raife
Posted: 09/25/20 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Figured it out...the low pressure settings were not saving (PEBKAC - Problem exists between keyboard and chair...)
