RV.Net Open Roads Forum: Tech Issues: 2-way refrigerator operation without a battery
 > 2-way refrigerator operation without a battery
dougrainer
Carrolton, Texas
Posted: 09/26/20 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
1985 Airsteam TTs had a RM 1303 3-way fridge as standard
https://www.airstream.com/owners/document-archive/product/tt/year/1985/
http://bryantrv.com/docs2/docs/rm1303.pdf
EDIT--using that link above, I went back as far as 1971 and they had "gas/electric combination" fridges as standard. Don't know the model for the fridge.
EDIT--the 1982s still say gas/electric combo, the 1983 says RM100.
seems to be a 3-way that uses 12v
http://bryantrv.com/docs2/docs/rm100parts.pdf
Ref here to a 1976 RM100 in an Airstream
https://www.airforums.com/forums/f425/19........o-cooling-l-kie-what-i-found-106531.html
So that is 1976 for a "gas/electric combo" that was an RM 100 that does need 12v. Still don't have when that "modern" type of fridge started being made for Rvs
1303 is AES and DOES require 12 volt for operation
RM-100 is the old very good standard Dometic non battery model. DOES NOT REQUIRE 12 VOLTS TO OPERATE.
That is why it is important for the OP to state MODEL NUMBER. Doug
2oldman
The Q
Posted: 09/26/20 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
We can hope.
BFL13
Victoria, BC
Posted: 09/27/20 08:13am Link  |  Quote  |  Print  |  Notify Moderator
OP is missing in action. [emoticon]
He said he has a two way in his 1985 but standard for 1985 is three way so we still don't know his model.
I missed the part where it can be a three-way but still not need 12v. I get that now. BTW, the 2410 in our 1991 truck camper has that two button system for lighting it, and does not have indicator lights. I did not realize that means it does not need 12v connected--interesting!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
dougrainer
Carrolton, Texas
Posted: 09/27/20 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Since the OP stated 2 way, I stated NO 12 volts for the RM 100. IF you have a 3 way RM 100, then you DO need a heavy Gauge 12 volt wire Positive and Negative. Doug
BFL13
Victoria, BC
Posted: 09/27/20 09:33am Link  |  Quote  |  Print  |  Notify Moderator
Yes, but I think the point is ? that you can have a 12v mode but still no 12v controls, so you don't need 12v except for the 12v mode. Wrong?
Since you are here to ask while I can, is there a clever way to know if the 2410 is on electric ok without having to go outside and feel it? The gas mode has that reflector but you can't see it unless it is dark, which is not so useful either when you can't see if it lit or not except by going outside.
2oldman
The Q
Posted: 09/27/20 10:52am Link  |  Quote  |  Print  |  Notify Moderator
I can hear mine.
dougrainer
Carrolton, Texas
Posted: 09/27/20 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
On a Dometic, the only way is to either test for hot on the cover or buy a clamp on AMP meter and test for the amp draw at the wires of the Heat Element. Doug
ANOTHER WAY----- Buy a CHEAP 120 non digital clock and wire it thru one of the 120 Heat element wires. When on 120, the second hand will be turning. I guess you could do the same with a 120 digital, it would then flash when 120 was supplied.
SORRY, Another easier way is to but a standard 120 volt small round LED light and install in the RV by the refer. Wire it thru one of the 120 element wires and when on 120 that LED light would be ON. Doug
Like this, Just need one tho. BUT will only show that the element HAS 120 volts, not if it is Heating
https://www.amazon.com/YC-9WRT-1R-120-10........ht+bulb+120+volt&qid=1601238731&sr=8-115
BFL13
Victoria, BC
Posted: 09/27/20 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the ideas! I already had the episode where the back outside was hot on 120 but the fridge stayed warm. Turned out to be not level enough. This little fridge is very fussy about levelling, moreso than the taller fridges in our other RVs.
I have a Kill-A-Watt, which I used to tell if there was any draw from the fridge when on 120v, but no convenient way to leave in as a display. I like the indicator lamp idea.
Can't hear any flame. You have to stand on a chair to raise the outside panel, and unscrew the metal cover over the burner to see the flame. PITA. I need to work on a shade for the reflector so you can see if it is lit up when it is not dark in the camper.
dougrainer
Carrolton, Texas
Posted: 09/27/20 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
The OLD Instamatic refers from the 70's and very early 80's, had to be almost perfectly level to cool correctly. What may look like level enough may be out of level enough to slow good cooling. Doug
ItsyRV
Desert SW
Posted: 09/27/20 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
DieselBurps wrote:
I have a basic question I can not find the answer to.
I have a Dometic 2 way fridge (propane/120volt) in a 1985 Airstream. I can not get the fridge to run on either 120 volts or gas.
I do not have a battery at this time.(I am on shore power)
Do I need a battery to run the fridge even though I am hooked up to shore power?
Is the battery required in order to "complete the circuit"?
I assumed since I am on shore power the fridge should work either way even though I do not have a battery.
An important think to consider is what was (as in OEM), may not be what is (as in changes over the years). As a result, you'll need to do a bit of looking as it could be a simple fix.
Let me give you an example. My refrigerator needs 12 volts to operate the control functions. It needs standard AC power or propane to cool down. If you read the specs and owner manual and refrigerator manual, removing the battery would not cause an issue with the control function while on shore power as the converter supplies it. BUT, over the years an issue arose that required abandoning the converter 12 volt circuit to the refrigerator, water pump and furnace. In it's place is a fuse block connected to the coaches' battery setup.
What that means is when the battery is removed, I must still connect all the positive cable together and all the negative cables together in order to complete the circuit. My point is no amount of what the refrig supposed to do or what the converter supposed to do or what is this or that matters since its nothing but connecting two cables together to make the circuit. The manuals wont show that. In my case, all a person has to do is look at what was (battery in place with all terminals bridged together) when thigs worked compared to what is when stuff stopped working (cables not together without battery) to see it's just a modification over the last 25+ years.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
