RV.Net Open Roads Forum: Class A Motorhomes: 2016 ITASCA TRIBUTE 31C Solar Upgrade
Open Roads Forum  >  Class A Motorhomes  >  Projects & Upgrades
 > 2016 ITASCA TRIBUTE 31C Solar Upgrade
Talshion
Tacoma, WA
Posted: 09/25/20 10:30am Link  |  Quote  |  Print  |  Notify Moderator
I am looking to add solar to the RV. It have a Residential Refrigerator in it that being ran off 3 Lead acid battery's at 300ApH. These last about 8 to 12 hours at best. I am replacing them with two lithium battery's at 200aph and adding one more in a few months for 300aph total.
I want to add solar but I'm not sure what I am needing. Since my system already has a 2000w inverter/charger in it that works with the generator and when driving.
I do not want to over charge the new battery's. Do I only need to get a Controller and a few Panels plus wiring.?
So is it as simple as running Solar Panels to a MPPT Charge Controllers directly to battery's. Is it really that simple?
Am I overthinking it or am I missing something.?
Thanks for the help.
Camping near Pearsonville, CA
Posted: 09/25/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Generally, you need one solar watt per battery amp hour but living in Washington you may need 1.5 or 1.75 watts per amp hour. Have you consulted a solar wiring chart to determine proper wiring? I use 10 gauge from the panels to the combiner box, 8 from the box to the controller and 6 from the controller to the batteries but my 3 panels are in parallel. Wiring distance is important too...longer the distance the bigger the wire. Don't limit any future additional panels by using small wire. Consider doing your panels in series too. The controller you buy needs to specifically say it works with lithium batteries. You'll love not needing a generator! Seems your current fridge is a power hog.
RLS7201
Just make sure that your MPPT controller is configurable for Li batteries. It's my understanding that your new MPPT controller will need to be able to stay at 14.4 volts until the Li batteries are full. Then either the MPPT controller will shut off or the controller built into the batteries will stop the charge.
You can't have too much solar. I like 24 volt panels. They are cheaper and allow smaller wire. Over size your MPPT controller, just incase you decide on more panels.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
2oldman
Mecca
Posted: 09/25/20 11:32am Link  |  Quote  |  Print  |  Notify Moderator
It's that simple.
Talshion
Tacoma, WA
Posted: 09/25/20 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Richard
Thank for you info on that. Was looking to do that.
Glad it is that simple.
Any reviews on MPPT controllers?
2oldman
Mecca
Posted: 09/25/20 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure you get one that's configurable for Li batteries. ie.. correct voltage, no absorb..etc. And one that will handle the solar amps you expect to harvest.
Outback makes top of the line.
Just a friendly correction.. it's ah, not aph
Talshion
Tacoma, WA
Posted: 09/25/20 11:42am Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
It's that simple.
Glad it that simple. Makes my like simpler.
Does anyone know a place for good deals on Panels and controllers?
Posted: 09/25/20 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
Most challenging part for me was the wiring.
2oldman
Mecca
Posted: 09/25/20 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Arizona wind and sun is a good, reputable place. Don't hesitate to pay a bit more for service after the sale.
pianotuna
Regina, SK, Canada
Posted: 09/25/20 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Consider Victron for the controller (Outback is good too)
I'll be going to SiO2 jars next summer as they can be run stone bone dead with no damage, unlike most other batteries.
Regards, Don
