RV.Net Open Roads Forum: Crack on outer wall of 2014 Lance 992
 > Crack on outer wall of 2014 Lance 992
Freep
Wisconsin
Posted: 09/26/20 10:03am Link  |  Quote  |  Print  |  Notify Moderator
A ladder fell over and hit our Lance and created a crack about 3-4 inches long. What should I use to repair/fill the crack? Just caulk or should I use some special cement?
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
joerg68
St. Ingbert, Germany
Posted: 09/26/20 10:06am Link  |  Quote  |  Print  |  Notify Moderator
How about a picture?
If you don't know how, try this: http://photoposting.is-great.net/?i=1
Kayteg1
California > Nevada
Posted: 09/26/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Fiberglass is easy.
Freep
Wisconsin
Posted: 09/26/20 11:43am Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 09/26/20 11:59am by Freep *
Kayteg1
California > Nevada
Posted: 09/26/20 11:45am Link  |  Quote  |  Print  |  Notify Moderator
That looks like stress crack, not hit crack?
Freep
Wisconsin
Posted: 09/26/20 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Could be a stress crack. A ladder was on the camper and then the jacks were lowered. Heard a crash and saw the ladder go down.
Discovered the crack days later.
joerg68
Posted: 09/26/20 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like a stress crack to me as well. Where exactly is it located? In the corner of a slideout cutout?
If it is indeed a stress crack, just filling/covering it will be a band-aid fix only.
The reason behind it may or may not be harmless.
For now, I would probably drill a stop hole at the end and cover it with sealant. Then, keep an eye on it to check if it opens up again or moves.
Freep
Wisconsin
Posted: 09/26/20 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
I haven't heard of a stop hole before. Thanks.
Yeah that's above the upper right corner of the kitchen slide out.
* This post was edited 09/26/20 12:56pm by Freep *
thedavidzoo
Tucson, AZ
Posted: 09/26/20 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
We have used this product several times before on fiberglass, etc. with great results.
Marine-Tex epoxy
https://www.amazon.com/Marine-Tex-Standard-RM305K-B-White-Bagged/dp/B07NYBKN51/ref=sr_1_10?dchild=1&keywords=marine+epoxy&qid=1601150131&sr=8-10
2014 Ram 3500 CrewCab Diesel DRW 4x4 4.10 Aisin, Torklift Fastguns, Upper Stableloads, Timbrens
2017 Northstar 12' STC
640W solar, 400Ah lithium LiFeMnPO4 batteries
Kayteg1
California > Nevada
Posted: 09/26/20 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Give us bigger picture where it is located.
Ladder might be coincidence, or last straw, but I bet my lunch it is stress-related crack.
You should investigate and reinforce the frame before patching the crack.
Just for crack covering - house siding caulk is good.
I have good experience with THIS ONE
