RV.Net Open Roads Forum: How to compress EMPTY air bags to remove
 > How to compress EMPTY air bags to remove
Gary.
Yukon, OK
Posted: 09/26/20 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Here we go again with a 2000 Harney Coach 37 foot Riata with Firestone Air Ride air bags. Now my son and myself have the air bag nuts off both the top and bottom. There is a 2 inch bolt sticking out the bottom and a 1 inch bolt sticking out the top. This type air bag has a large bell shape base that it sits on. We are having a heck of a time trying to compress this enough to get it out! He can push down on the top far enough to get the top bolt to clear, but then the bottom one is so long that we are unable to remove the bag from the position? Just asking if someone has a method that we have not thought of yet and can save us. We tried a 10 inch C clamp but looks like we need a 12 inch one. Once again any and all help really appreciated. TIA Gary
gbopp
The Keystone State
Posted: 09/26/20 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check Youtube?
DrewE
Vermont
Posted: 09/26/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Rather than compressing the air helper spring, what about extending the suspension by jacking up the frame (not the axle) somewhat? Doing so safely isn't exactly trivial, but it's also far from impossible; jacking and supporting on cribbing or suitable stands would be a good plan. If you have leveling jacks, they could be used to do the jacking (but I wouldn't trust them to do the holding when I'm underneath with my hands working in a pinch and crush zone).
MrWizard
Traveling
Posted: 09/26/20 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
X2. Use bottle Jack's or RV hyd levelers
And place Jack stands , under the frame rails
Use chock blocks on the wheels so it doesn't too off the Jack stands
Radiate The Happy
1997 F53 Bounder 36s
Lt46
Central Florida
Posted: 09/26/20 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Since mine were being replaced I simply used a sawsall and cut the rubber.
Peter & Dawn
97 Winnebago Adventurer 37RW
F53/460 w/ tag axle
96 Prowler 27X SOLD
IAFF L-792 (Ret.)
bdpreece
Yuma Arizona / Oregon Traveler
Posted: 09/26/20 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Cut them out, Your just going to throw them away anyway.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
jjrbus
FT Myers FL
Posted: 09/27/20 05:35am Link  |  Quote  |  Print  |  Notify Moderator
I was trying to remember how I removed mine? Cut! I was thinking use vacuum, if bags are bad will not hold vacuum.
The new bags will have nylon straps, holding them compressed. Do not cut the straps before trying to install.
Gary.
Yukon, OK
Posted: 09/27/20 10:31am Link  |  Quote  |  Print  |  Notify Moderator
We are still mulling this operation over. We hate to cut them up to get them out because then we are wondering what we have to do to get the new ones in! If we had the situation where they were loose enough to just take out we would feel a lot more comfortable about installing the new ones. Does anybody know if the new ones are compressed more in order to make it easier to replace them? We may try DrewE's idea. But today is Sunday so we are not going to do anything but think about the situation. But thanks for all your ideas and if anyone else has any other ideas we would appreciate them also. Gary
Gary.
Yukon, OK
Posted: 10/05/20 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Still trying to work on this, but haven't had time to stay on it, so kicking it back in case somebody has more ideas. Thanks again to everybody.
RLS7201
Posted: 10/05/20 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Vacuum.............Use an AC vacuum pump or run a small hose from the intake manifold of a gas engine.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
