RV.Net Open Roads Forum: Travel Trailers: Winnebago Minnie Plus Blowing Fuses
 > Winnebago Minnie Plus Blowing Fuses
wrpowell2002
near Phoenix, Arizona
Posted: 09/26/20 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2019 Minnie Plus travel trailer that blows 20-amp fuses immediatly after applying power. I noticed a blown fuse indicator light when I plugged it in today to prepare for a trip. The fuse is labled Slide 2, but I only have 1 slide out. Something else is shorting the circuit. Anyone have suggestions on how to do some troubleshooting? The slideout I have works even with the fuse blown. Appreciate any help. Thanks.
Camping near Pearsonville, CA
Posted: 09/26/20 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
If everything works with the fuse blown, you could just leave it for your trip.
GDS-3950BH
DC
Posted: 09/26/20 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Its not uncommon for the manufacturers to pinch a wire somewhere, such as between frame and floor, or to run a screw or staple through a wire, or water line. Junk construction to no end. Find the wire connected to the terminal for said fuse and chase it.
Flute Man
Payson, Arizona
Posted: 09/26/20 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
It might not be easy to find. It might help if you determined what didn’t work when the fuse was blown. It might give you a clue. Question: does it blow immediately every time you put a new fuse in?
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
wrpowell2002
Posted: 09/26/20 11:40pm Link  |  Quote  |  Print  |  Notify Moderator
The replacement fuse blew immediately when I turned the power back on. I will dig into it more to see what is not working. Something is shorted. Thanks for responding.
