RV.Net Open Roads Forum: Tow Vehicles: Auto tire deflate/inflate
Search only in Tow Vehicles
 > Auto tire deflate/inflate
N-Trouble
NorCal
Posted: 09/26/20 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
How many would pay for this as a new truck option??? I know as someone who frequent offroads I would pay good mioney. Screw the 18 stinkin useless cameras and navigation BS. Give me something useful...
It amazes me with all these fancy BS truck options we have these days I still have to bust out the air compressor and hose every time I want to hook up the trailer.0
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
noteven
Turtle Island
Posted: 09/26/20 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Give the folks at Tire Pressure Control up in Canada a call for your central tire inflation needs.
Monterey, California
Posted: 09/26/20 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
Gee, tell us what you really think! Let it all hang out! lol
Seriously an on board air compressor can break...expensive...like all the navigation stuff. I’ll keep my HF unit and my iPad Forest Maps.
Flute Man
Payson, Arizona
Posted: 09/26/20 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
At one time the H1 Hummers had that feature.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
valhalla360
No paticular place.
Posted: 09/27/20 05:20am Link  |  Quote  |  Print  |  Notify Moderator
Very few trucks ever go off road. Of those, most are not serious enough to mess around with tire pressure (yes, I understand the benefits but for light duty off road they just don't)
Most do back up on a regular basis.
Manufacturers are well aware and offer options that people will use.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 09/27/20 06:07am Link  |  Quote  |  Print  |  Notify Moderator
I would like a dash button that lowered my rear tires for daily driver use or raise hauling loads. Better yet a knob or sliding bar, that let one set the pressure. Every time Costco rotates my tires, I have to sit there and let the rear back down from 80 PSI before driving off their lot. I have even showed them the pressure chart that at 45 PSI the tires have a 2470 lb capacity, 4940 for a rear axle that weights around 3300-3500 pounds. No go sir, door jam says 80 pounds for rear tires!!!! And I say, do you think the rear axles is at it's rated 7,000 lbs right now???
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it!
BenK
SF BayArea
Posted: 09/27/20 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Agree with the OP on "...Screw the 18 stinkin useless cameras and navigation BS...."
But, am okay with a bicycle hand pump, electric pump, etc and had them when off road a lot
Best was just a 10 gallon tank with a Schrader valve filled up to 120 PSI
Aired all 4 over sized, flotation tires back up enough to run on the highway till a gas station was found. Then finish airing them up
If the OP is filling air bags...they don't take much air...IMHO
-Ben Picture of my rig
Groover
Pulaski, TN
Posted: 09/27/20 07:01am Link  |  Quote  |  Print  |  Notify Moderator
That is low on my priority list. On the other hand, air adjustable height suspension is very high. Since that requires a compressor it should be easy to add a manual tire inflation feature while at it. I don't foresee ever wanting the added complexity of auto inflate even if it was free. I just wouldn't use it that much.
ShinerBock
LVTX
Posted: 09/27/20 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I would love the feature and would gladly pay for it. Between having to go off road at the farm, deer lease, and the beach it would get used.
Another benefit is that I would be able increase my rear PSI up to 80 when towing and back down to 50 when not towing for a smoother ride.
2014 Ram 2500 CTD
Highland Ridge Silverstar 378RBS
BenK
SF BayArea
Posted: 09/27/20 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Curious...
Anyone know how these work ?
Either a seal between the rotating tire/wheel to a stationary air line on the hub somewhere.
Or, a tiny pump inside the tire cavity hooked up to a special Schrader valve. Assume a counter weight 180* apart.
One per tire
Bluetooth interface
Or is there an extremely nifty design ?
Too many parts to fail for me to consider
