RV.Net Open Roads Forum: Class C Motorhomes: Is CG info available from MFG's
 > Is CG info available from MFG's
pauldub
North of Seattle
Posted: 10/08/20 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Somewhere on the interwebs there is a formula for overall length versus wheelbase that is supposed to suggest how well the vehicle will track. Someone has decided that there is a particular ratio that is desirable. I don't know how valid it is or how one would easily decide what is good. It might be worth searching for it and see if it seems reasonable. If you had CG location, I don't know how you make a valid decision as to whether or not it was good or bad.
Gjac
Milford, CT
Posted: 10/09/20 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
What you are referring to is the WB/L ratio. You divide the WB in ins to overall length in ins to get the ratio. For example a 24 ft MH would have a WB usually of 159 ins and an overall length of 288 in. That would yield a ratio of .55 or 55% which is suppose to be very good(More than 50%). However many on here report the front end is too light as previous posters have noted which causes handling issues. I was after actual axle weights which I have not found on mfg web sites or on the MH I was interested in. Knowing the CG only helps to estimate the weight distribution.
AJR
Close to Madison Wisconsin
Posted: 10/09/20 06:25pm Link  |  Quote  |  Print  |  Notify Moderator
Why is this CG important?
2014 Leprechaun 290QB
Chevy 2400 6.0
2015 GMC Terrain AWD
Gjac
Milford, CT
Posted: 10/12/20 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Read the previous post to paul. CG is only important when you don't know actual axle weights. Which you can see from my previous posts I have not been able to find on web sites or on stickers inside the MHs or asking the dealers. If you at least know where the CG is in front of the rear axle you can at least get a idea of the weight distribution. Most on here with 24 ft C's say their front end is too light and causes handling issues and have added suspension upgrades to improve handing.
AJR
Posted: 10/12/20 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
So you are asking about weight ratio front to rear. I missed that, I guess.
