RV.Net Open Roads Forum: Fuel mileage 5th wheel vs travel trailer
 > Fuel mileage 5th wheel vs travel trailer
time2roll
Posted: 09/28/20 11:53am Link  |  Quote  |  Print  |  Notify Moderator
TomG2 wrote:
time2roll wrote:
3 mpg seems a bit much to lose. From 12 down to 9 mpg is 25%. I think speed, wind, terrain might also be an issue. See how next trip goes.
Who gets 12 mpg towing almost 10,000 with a gasoline fueled tow vehicle? "gets less gas mileage by about 3 mpg". Probably lucky to get 8 mpg which resulted in 5 for the travel trailer. Since we don't know the route or even the average speed, simply saying 40% less gas mileage is meaningless.
We still don't know the numbers or how it was calculated.
12 is high? Sure. Say it was 9 and dropped by 3 to 6 mpg. That is a 33% drop. Seems high percentage for like conditions.
675w Solar pictures back up
spoon059
Just north of D.C.
Posted: 09/28/20 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
StirCrazy wrote:
I had a 29 foot 8000 lb trailer and I got about 12 mpg, then I got a 39 foot 14000lbs 5th and I went up to 16.5 mpg.
Steve
No you didn't. Maybe once, going downhill from the gas station... unless you have one of those super carburetors the govt tried to destroy...
2015 Ram CTD
2015 Jayco 29QBS
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 09/28/20 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
I pulled a 24' TT, a 30' TT, and a 35' Fifthwheel all with the same truck, a 2005 Chevy Extended Cab Dually with the Duramax and got almost the same mileage with all three, at least not enough difference that you could really tell.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
dieseltruckdriver
Black Hills of SD
Posted: 09/28/20 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
When we went from our S&S truck camper to our first 5th wheel, there was no difference in mileage. I honestly did expect mileage to get a little worse, but there was no change. There was a large weight difference, but not as much in aerodynamics.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
travelnutz
West Michigan - On the Lakeshore
Posted: 09/28/20 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
hornet28,
Yes, A 5th wheel has a considerably better aerodynamics flow being a continuous surface for air flow than a TT which is located behind the tow vehicle and thus the flow is disrupted along the surfaces.
BTW, perhaps your brother and his wife each drove Ford diesel trucks and kept a trailer down at Old Town Campground n Retreat at Old Town FL where they'd stay at in the winter often between RV hauling trips back when Joe and Linda owned the CG. They lived in Muskegon. Had your Bro passed several years ago and his wife still hauled RV's for a few years and later had a smaller trailer at the CG? We live in Grand Haven about 13 miles south of Muskegon and have been going to Old Town CG for about 10 or so years now for about 2-1/2 months in winter. Just wondering.
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
StirCrazy
Kamloops, BC, Canada
Posted: 09/29/20 09:02am Link  |  Quote  |  Print  |  Notify Moderator
MFL wrote:
Wow Steve...that is terrific mpg towing a 14K FW! I'm not sure my gas 6.2 will get 16.5 mpg running empty? Maybe on a still day at 55 mph.
Jerry
that is Canadian gallon and a modern diesel truck. empty I get 21 to 24 mpg depending how I drive.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
StirCrazy
Posted: 09/29/20 09:04am Link  |  Quote  |  Print  |  Notify Moderator
spoon059 wrote:
Steve
Diesel. and I get 16.5 mpg (canadian gal) all the time in the mountians. on the praries it goes down because of wind and long long slight inclines.
Steve
rhagfo
Portland, OR
Posted: 09/29/20 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Well seeing how a Canadian (Imperial) gallon equals 1.201 US gallons, while 16.5 mpg is good it needs to be reduced by at least 20%.
Powertour
Nevada
Posted: 09/29/20 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
FIRECHIEFBUBBA wrote:
We just sold our 2011 Crossroad Cruiser Patriot 5th wheel for a 2020 Winnebago Voyage travel trailer. The 5th wheel was 34 foot and weighted 9700 pounds. The new Winnebago is 36 foot and is 1500 pounds less at 8200 pounds. The question is the t re mailer gets less gas mileage by about 3 mpg that the taller heavier 5th wheel. Both pulled by same truck .My thought is the weight distribution and pulling of hitches? Any thoughts?
Back in the day I went from a tag toyhauler to a conventional 5ver. 5ver was longer (by like 7') and was taller than the toyhauler. I got at least 3mpg better going to the bigger & taller 5ver. I also was able to crest many hills in a higher gear than I could with the tag behind trailer.
2015 Itasca 25b Ford E350 V10
otrfun
On The Road
Posted: 10/02/20 08:08am Link  |  Quote  |  Print  |  Notify Moderator
We sold our 33ft 5th wheel and purchased a 33 ft. TT. Expected our MPG's to improve with the lower, lighter TT, but it didn't. Towed each trailer more than 10,000 mi. TV was a '16 Ram 3500 Cummins SRW SB.
33 ft. 5th wheel. 12,500 lbs. loaded. 13.5 ft. high: ~11.2 MPG's.
33 ft. TT. 10,000 lbs. loaded. 12 ft. high: ~10.5 MPG's.
Typically towed at 60-65 mph.
