RV.Net Open Roads Forum: Around the Campfire: Concrete block in my stove !
 > Concrete block in my stove !
Guy Roan
Posted: 09/27/20 05:48am Link  |  Quote  |  Print  |  Notify Moderator
I have seen it all now!
Our thirty three year old built in dishwasher leaked at the pump, and over the years I made a few repairs so figured it was time to spring for a new one which we did. We decided that since the stove next to it was on its last legs and the same age to replace that also.
Yesterday we bought the new stove, and in putting it in the vehicle found that it seemed almost twice as heavy as the dishwasher.
We got it home and installing it I had to do some work on the back since it blocked where part of the 220 volt receptacle that is in the floor.
I
There was a large metal covering which had two long bolts running through, believe it or not, a precast concrete block.
Needless to say, the concrete block is now long gone!
If I hadn't already made some modifications, and if it wasn't holding up the dishwasher installation, I would have returned it.
Guy
jetboater454
Camping or home
Posted: 09/27/20 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Made in Mexico stove? [emoticon] They smuggle drugs in cast concrete and fake concrete rocks.
2011 Toyota Tundra DC Long Bed
2001 Harley Dyna Lowrider
Redcatcher70
Beebe, AR
Posted: 09/27/20 06:54am Link  |  Quote  |  Print  |  Notify Moderator
Could have been a counter balance weight to keep stove from tipping over when door is fully opened. Our new stove had a special bracket with it to screw to the floor at the rear of stove, the rear leg slipped into a slot in the bracket. Call and the Mfg. and check it out...
* This post was edited 09/27/20 07:48am by Redcatcher70 *
Dave & Pat
2008 Hi-Lo 19T
2004 F250, XLT Crew Cab, V10, finally, enough power!
"No kids, no pets, made it to retirement"
Lynnmor
Red Lion
Posted: 09/27/20 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Counterweight.
PawPaw_n_Gram
On the Road Somewhere
Posted: 09/27/20 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Tell the wife to not set the Thanksgiving turkey on the stove door, or it will tip over on her.
Full-Time 2014 - ????
“Not all who wander are lost.”
"You were supposed to turn back at the last street."
2012 Ram 2500 Mega Cab
2014 Flagstaff 832IKBS TT
Guy Roan
Posted: 09/27/20 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
Counterweight.
If so, it sure is (was) over kill, since they included brackets for the stove front to prevent it from tipping forward.
Guy
JIMNLIN
Oklahoma
Posted: 09/27/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
It may have to do with heating levels vs temps running up and down using lots of energy. Kinda' like all the fire bricks in a good wood heating stove helps retain heat.
navegator
San Diego CA.
Posted: 09/27/20 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
That concrete helps maintain the heat so that the electric element is not having to turn on every few minutes, less consuption of electric power for the amount of heat retained.
navegator
Bowling Green, KY
Posted: 09/28/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Silly question: Did you read the manual to see if the block is mentioned in any way? [emoticon]
Geo*Boy
Unknown
Posted: 09/28/20 07:26am Link  |  Quote  |  Print  |  Notify Moderator
navegator
WOW!![emoticon]
