RV.Net Open Roads Forum: Fifth-Wheels: Marshall changeover regulator doesn’t indicate empty tank
 > Marshall changeover regulator doesn’t indicate empty tank
howardwheeler
West, Texas
Posted: 09/27/20 09:47am Link  |  Quote  |  Print  |  Notify Moderator
I have a fairly new (maybe one to two year old) Marshall Excelsior two stage propane regulator that has stopped changing the green sign in the upper bulb to red when the tank the lever points to is empty. It appears as though it is changing over to the other tank but definitely the bulb always stays green—-even with the tank removed! Is this fixable? What would cause this? If I’m not mistaken ( it’s been too long) I may have encountered this on my previous regulator, also a Marshall. Is my propane “gunky” and mucking up the signal bulb from being able to move up and down? What is going on? Anybody want to hazard a guess?
bob213
Fresno, CA
Posted: 09/27/20 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
It could be oil in the propane. Mine does similar but it does not show red nor green. It does switch over.
time2roll
Posted: 09/27/20 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it is fixable. Replace it with a Cavagna brand regulator. Better accuracy, easier to read.
675w Solar pictures back up
howardwheeler
West, Texas
Posted: 09/27/20 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Does the Cavagna indicator work on a different principle than the Marshall and therefore not as likely to malfunction? Oil does seem to form in my propane lines.
time2roll
Posted: 09/27/20 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
If you fill at the same place I would find a new supplier. No I don't think any regulator is immune from being fouled with bad propane. I also recommend new Cavagna pigtails.
Old-Biscuit
Verde Valley
Posted: 09/27/20 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Indicator works off of cylinder pressure
When pressure in cylinder drops to roughly 10# the regulator swaps to the other cylinder
When you move lever the pilot valve allows full cylinder pressure in causing Red to move to Green indications
Pilot valve is gumming up and wouldn't matter which regulator you have if propane supply is gummy
Rvpapa
Alberta , Can.
Posted: 09/28/20 11:08am Link  |  Quote  |  Print  |  Notify Moderator
Check that the plastic cover over the r/g indicator has not been pushed down covering the space for the red to show.
Art
