RV.Net Open Roads Forum: Tech Issues: Wiring , converter , not sure
 > Wiring , converter , not sure
booten
Rocky Mt VA
Posted: 09/27/20 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Our motorhome is 50 amp. Today when we plugged at the campground the ac in front worked but nothing else. Switched to 30 amp everything worked. Unplugged motorhome started the generator everything came on then all started flickering and went out but the generator was still running. Any idea what could be going on? Thanks
Roger & Ruth
It's not just camping, It's a lifestyle!
2012 Harley Street Glide Ember Red Sunglo
2015 Harley Tri Glide
time2roll
Posted: 09/27/20 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Good chance you have a bad connection. Maybe in the transfer switch.
Volt meter would tell more.
675w Solar pictures back up
Matt_Colie
Southeast Michigan
Posted: 09/27/20 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Roger,
What you are seeing is absolutely a symptom of a bad connection at the pedestal. Do you carry a meter? If not, you should. Get a juice friendly acquaintance to walk you though what to do with it.
The reason everything worked with the 30amp adapter in there is that all of your equipment is good.
Tomorrow, go out there again and flip the 50 amp breaker on and off a couple of times and try it again. If the condition persists (only one side works) then tell the campground that the breaker has failed and should be replaced. If things work this time, tell the campground that the breaker is failing and should be replaced. (They won't until it doesn't work at all.)
Good Luck Roger
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
Bobbo
Wherever I park
Posted: 09/27/20 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the generator breaker tripped too. Maybe because of the problem in the transfer switch.
Bobbo and Lin
cavie
Posted: 09/28/20 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Matt_Colie wrote:
Roger,
Good Luck Roger
Matt
Problem not at pedistal. OP stated it happened on gen also. Problem is with shore power cord, Trasfer Switch, or Main Breaker. this would be a good time for a volt meter.
Matt_Colie
Southeast Michigan
Posted: 09/29/20 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Matt_Colie wrote:
Roger,
Matt
Oops, I did miss that when I wrote.
He does need a meter.
Matt
