RV.Net Open Roads Forum: Why Didn't I Think of This Before?
 > Why Didn't I Think of This Before?
Matt_Colie
Southeast Michigan
Posted: 09/29/20 08:25am Link  |  Quote  |  Print  |  Notify Moderator
Obiwan,
I have never seen a RV that did not have a gravity/atmospheric potable fill capability. I personally believe that omitting that was an amazing stroke of stupid. How do you winterize it (among other things).
I am not sure what I would do in your case but, if it works out functionally, you could T into the line that is the pump suction from the potable tank and bring it out where you can access it to mount a place that you can pour into.
Good Luck
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
DrewE
Vermont
Posted: 09/29/20 09:45am Link  |  Quote  |  Print  |  Notify Moderator
I have such an RV, and it never really seemed to me a grave drawback. Normal filling is via the city water connection (with a pressurized hose), by opening a fill valve. I've yet to encounter a dump station that did not have an associated potable water fill hose/spigot, though doubtless a few do exist somewhere, so I've always just used the pressure fill.
Winterization is performed by a typical winterization suction inlet, sticking a hose into the bottle of antifreeze and pumping it about the pipes. (Actually, I use compressed air to winterize, but that's neither here nor there.) I don't see why one would use a gravity fill to winterize if there were any other options: why put a good bit of antifreeze in the fresh water tank, and then have to take extra steps to rinse it out in the springtime? I'd think it far better in any case to just pump it through the piping and leave the tank empty.
A system with a pressure fill valve and a winterization inlet can (nearly always) be set up to pump water from an external container into the tank by using both at the same time. It's not as quick as a gravity fill, but involves less lifting and pouring.
memtb
Wyoming
Posted: 09/30/20 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Matt, our 5th wheel has a connection for a water hose to directly fill the fresh tank....no valves to open! In fact, every 5th wheel we’ve owned since 1993, had the water hose connection. Our class c has the more typical gravity feed! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
CharlesinGA
South of Atlanta, Georgia
Posted: 10/08/20 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
Why would you avoid putting the water from the jugs into the existing fill port?
Get a second RV water pump and some clear tubing. A couple wires to the battery and you are filling the tank while you make a sandwich.
It seems a fair number of people do just this. Buy a pump like you have in the RV, you will always have a spare. Pump will move water rather fast as it is free flowing and not building pressure.
Charles
beemerphile1
Ohio
Posted: 10/09/20 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
My RV doesn't have a gravity fill but it does have a vent. Pull the screen from the vent and you can add water using a smaller hose.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
