RV.Net Open Roads Forum: Reverse Polarity code When Plugging in at Home
 > Reverse Polarity code When Plugging in at Home
Lakejumper
Northern California
Posted: 09/28/20 02:19am Link  |  Quote  |  Print  |  Notify Moderator
In the past I have plugged my RV in directly to my 30 receptacle in the garage, without any issues. Today a friend who is visiting plugged into my 30 amp plug, but placed a surge protector in the middle of the power cords and got a Reverse Polarity error code. Why is this happening?
Lakejumper
2016 Winnebago Vista LX 30T
2012 Chevy Equinox
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 09/28/20 03:51am Link  |  Quote  |  Print  |  Notify Moderator
Whomever wired his EMS did it bass-ackwards. Anything reconnectable on the incoming shore power from plug to his breaker panel is reconnectable. But it is commonly it's in the umbilical cord.
TenOC
On the road -- Full time
Posted: 09/28/20 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Or maybe the 30 receptacle in the garage is wired wrong and it always had a problem but was never checked.
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
bob_nestor
murphy
Posted: 09/28/20 06:28am Link  |  Quote  |  Print  |  Notify Moderator
This is what I'd check first. Getting the Hot and Neutral swapped when wiring the plug is very easy to do. In the old days before the 3rd wire ground was introduced it usually didn't matter how you wired the plugs. But with the 3rd wire ground and with a lot of the newer electronics it does matter and can make a difference (it actually makes a difference on 2-wire connections too which is why most plugs can only plug in one way with the larger blade on one side of the plug). I always use a tester on any new circuit or plug I install just to make sure I did it right.
* This post was edited 09/28/20 06:35am by bob_nestor *
BurbMan
Islip, Long Island
Posted: 09/28/20 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Agreed, if OP was not using a polarity checker the garage outlet has likely been wrong from the get go and he never knew it.
2015 Ram 3500 4x4 Laramie Crew Cab Long Box, Cummins diesel
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
wildtoad
Blythewood, SC
Posted: 09/28/20 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Call an electrician and have them check the wiring.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Bobbo
Wherever I park
Posted: 09/28/20 07:36am Link  |  Quote  |  Print  |  Notify Moderator
This can be done before calling an electrician.
Go to a big box hardware store and buy a no-contact voltage tester. They are not expensive. That will tell you exactly which slot on your 30 amp outlet is hot. You can then tell if the outlet is wired backwards. With the round slot at the top, the hot slot should be lower left.
Bobbo and Lin
Dave H M
IL
Posted: 09/28/20 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Bpbbo, If you hare some elcheapo HF volt ohm meters laying around already, won't they suffice for the testing?
BB_TX
McKinney, Texas
Posted: 09/28/20 08:22am Link  |  Quote  |  Print  |  Notify Moderator
This is the best answer. And that tester is handy to have around any way. Here is how it should be wired.
http://www.myrv.us/electric/
* This post was edited 09/28/20 08:28am by BB_TX *
K Charles
Connecticut
Posted: 09/28/20 08:23am Link  |  Quote  |  Print  |  Notify Moderator
A volt meter stuck in the long spot and the round hold should be zero.
