RV.Net Open Roads Forum: Fifth-Wheels: TPMS with Truck or Aftermarket
 > TPMS with Truck or Aftermarket
SeaVee
Maryland
Posted: 09/28/20 04:29am Link  |  Quote  |  Print  |  Notify Moderator
I noticed on some of the new tucks today, you can get them with Trailer TPMS monitoring. It seems they monitor pressure, but not temperature. I know most aftermarket systems like TST monitor both.
Having a system with a built in screen would be nice with one less screen to look at, but wondering how important is temperature monitoring? They systems cost about the same, but more just wondering the best way to go.
way2roll
Wilmington NC
Posted: 09/28/20 06:09am Link  |  Quote  |  Print  |  Notify Moderator
Temperature monitoring is important. An underinflated tire will generate more heat and alert you to the problem before a blowout as should PSI monitoring however, temps can also be indicative of a hung brake, and overheating hub etc. If you are going to get a monitoring system, you might as well get one that monitors everything.
2020 FR Cedar Ridge Silverback 29rw
Lynnmor
Red Lion
Posted: 09/28/20 07:33am Link  |  Quote  |  Print  |  Notify Moderator
The temperature feature only reports the reading beyond the valve stem, that is not going to be a reliable way of determining brake and bearing issues.
way2roll
Wilmington NC
Posted: 09/28/20 07:59am Link  |  Quote  |  Print  |  Notify Moderator
You may have to explain this to me. If I have a brake stuck and it heats the wheel which heats the tire and I see it on my TPMS, how is that not helping? By deduction, if my PSI is where it needs to be I can assume there is another problem than the tire. Are you suggesting a high temp reading on a TPMS isn't helpful? I sure would want to know if one wheel was significantly hotter than another. Sure beats not knowing.
Lynnmor
Red Lion
Posted: 09/28/20 11:17am Link  |  Quote  |  Print  |  Notify Moderator
I do have the TST 507, the sending unit is whipping around in the wind keeping the temperature down. It would take extreme heat to bring the sensor to the point of alarm, but by then the air pressure would have climbed to the point of alarm anyway. I had Chinese wheel bearings that were failing to the point of turning all the red grease metallic gray and the TPMS showed normal temperatures. Helpful? Maybe a little.
way2roll
Wilmington NC
Posted: 09/28/20 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Interesting. I too have the TST 507 and find it pretty accurate. Friend shot his high dollar laser temp gauge on my tires and they were pretty close to what the TST read. It even picks up small changes like when one tire was in the sun while driving as opposed to the other side that was not. Maybe yours needs calibrated. To each his own, but I prefer to have both PSI and Temp and find each helpful and fairly accurate.
miltvill
Ft. Lauderdale FL
Posted: 09/28/20 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
My truck came with the optional 4 TMP sensors ($50) option. When I get my 5th wheel I have to have the sensors installed. They will read temp and pressure and display it on my dash. It is part of the towing option om my 2020 GMC.
2020 GMC Denali\Duramax 3500HD Dually Crew Cab
Sold-Trail Cruiser TC23QB
