RV.Net Open Roads Forum: Tech Issues: Hot water heater not hot enough
 > Hot water heater not hot enough
rburke
Antioch, Illinois
Posted: 09/28/20 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Hello
I am a first time travel trailer owner, bought a 2013 Skyline Nomad and working to figure it all out. So far so good, one thing I can't seem to figure out is how to adjust the hot water. It more warm than hot, i do not see any way to adjust the temp setting. Any advice or what to check would be appreciated.
Thank you!
way2roll
Wilmington NC
Posted: 09/28/20 06:31am Link  |  Quote  |  Print  |  Notify Moderator
First thing I would check is to see if your winterization bypass valves are still on.
2020 FR Cedar Ridge Silverback 29rw
12th Man Fan
Flower Mound , Texas
Make sure your outside shower is turned off at the handles if you have one. If it is cut off with the button on the shower head it allows cold water to mix with the hot.
There is no temp. adjustment on the newer water heaters. If it is working right it will be plenty hot.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
rburke
Antioch, Illinois
Posted: 09/28/20 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Ok - need to find out about these bypass valves, there is an outdoor shower I have not opened it up yet, will take a look. Thanks!
way2roll
Wilmington NC
Posted: 09/28/20 08:06am Link  |  Quote  |  Print  |  Notify Moderator
Yes, some background, when winterizing and running RV antifreeze through your plumbing, the water heater has a set of valves in the plumbing connections to bypass it. Since the water heater can be drained there is no sense in filling it up needlessly with 6 gals of RV antifreeze. So it's bypassed. If you don't turn the valves back when un-winterizing you won't get hot water.
If that is not your issue, are you using LP or electric to heat the water?
Old-Biscuit
Verde Valley
Posted: 09/28/20 08:27am Link  |  Quote  |  Print  |  Notify Moderator
WELCOME!
Post Brand and Model for specific info
I take it water heater works...but water is not hot...correct?
Then most likely issue is the 'bypass' valve on water heater is still open
You will have a Cold Inlet (bottom), a Hot Outlet (top) and a line that connects cold to hot (bypass)
Cold needs to be open, Bypass CLOSED and Hot open (if it has a valve ---probably uses a check valve in Hot out)
Water temp is Pre-set via a temp t-stat (bi-metallic disc) no adjustments
Suburban...130*F
Atwood.....140*F
dougrainer
Carrolton, Texas
Posted: 09/28/20 09:38am Link  |  Quote  |  Print  |  Notify Moderator
IF automatic Ignition there is no adjustment. The quick way to determine how hot is to run until the flame shuts OFF and then open the outside POP OFF safety valve. IF that water comes out extremely hot, your WH is operating to spec and you need to look at possible Bypass valves or outside shower valves open. Doug
Old-Biscuit
Verde Valley
Posted: 09/28/20 10:10am Link  |  Quote  |  Print  |  Notify Moderator
CAUtION:
Opening T&P Relief Valve after heating cycle has finished WILL BLOW very hot water under high pressure EVERYWHERE
Scalding can occur within seconds
rburke
Antioch, Illinois
Posted: 09/28/20 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all! Heading back up there this weekend I will go through it all and post any updates.
rburke
Antioch, Illinois
Posted: 09/28/20 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Trailer is a 2013 Skyline Nomad Joey Select M298
