RV.Net Open Roads Forum: Tech Issues: Hot water heater not hot enough
 > Hot water heater not hot enough
Old-Biscuit
Verde Valley
Posted: 10/01/20 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
rburke wrote:
Trailer is a 2013 Skyline Nomad Joey Select M298
That nice....
What Brand/Model is Water Heater
Atwood gas/electric 6 gal/10 gal
Suburban gas/electric 6 gal/10 gal
Similar but different controls components so Brand/Model is helpful
Simple solution would be finding bypass valve open or shower not valved out using knobs resulting in Warm Water vs HOT
rburke
Antioch, Illinois
Posted: 10/05/20 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Ok thanks all the issue was definitely the bypass! I found the valve and turned it off and now have nice hot water while running in propane. The water is not getting hot running on electric, its warm but not hot so there is some failure in the electrical component of the water heater. Have not had time to diagnose yet but any pointers are much appreciated.
wopachop
Who run bartertown
Posted: 10/05/20 08:35am Link  |  Quote  |  Print  |  Notify Moderator
rburke wrote:
Any advice or what to check would be appreciated.
Advice given to me by professional plumbers over the years is to never ever ever touch the relief valve. Its not there to act as a tank vent. Its an emergency valve that never needs to be opened.
way2roll
Wilmington NC
Posted: 10/05/20 08:45am Link  |  Quote  |  Print  |  Notify Moderator
That's great, and thanks for reporting back. If it works fine on LP but not so well on electric, could be simply that the anode rod is bad and needs replacing.
2020 FR Cedar Ridge Silverback 29rw
DrewE
Vermont
Posted: 10/05/20 10:43am Link  |  Quote  |  Print  |  Notify Moderator
Ummm...the anode rod has nothing to do with the electric heating part specifically. It exists (on water heaters with steel tanks) to prevent corrosion to the tank by being more reactive and corroding first. The electric element would heat just as well with and without the anode rod. Atwood heaters, with their aluminum tank, have no anode rods and work fine on electric power if equipped that way.
Electric heating can take a little while on RV heaters, since the heating element isn't as powerful as the gas burner. If, after a sufficiently long time, the electric element gets water warm but not hot (and keeps it warm indefinitely), then clearly the element itself is operating, so the fault pretty much must be in the thermostat or control system.
rburke
Antioch, Illinois
Posted: 10/05/20 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I will try again and give it some more time. My hot water tank is plastic and I do not see any control system to control temp. I have heard from some folks in the park that the electrical heating element can fry out if its run while the tank is empty. I am learning, but still a newbie
Dusty R
Charlotte Michigan 48813
Posted: 10/05/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Most likely the heating element has burned out.
Dusty
wopachop
Who run bartertown
Posted: 10/05/20 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
What he is saying is that its possible the internal temp control is shutting off the electric element premature. You cannot adjust this yourself.
Your friends are correct you need water inside the tank before you turn the heat on. Set it to electric again, wait an hour and see if the water is finally hot.
