RV.Net Open Roads Forum: Towing: Tow King Tires
Search only in Towing
Open Roads Forum  >  Towing
 > Tow King Tires
mkirsch
Rochester, NY
Posted: 09/29/20 07:32am Link  |  Quote  |  Print  |  Notify Moderator
mrad wrote:
They are G rated
What are the date codes?
They could be J-rated but if they're too old they're rotten.
mrad
Prineton, MN
Posted: 09/29/20 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
NOT SURE. We will be lookin gat it again tomorrow. I will check then.
mrad
Prineton, MN
Posted: 10/01/20 03:06am Link  |  Quote  |  Print  |  Notify Moderator
We looked at the coach again yesterday. The tires are actually Power King tow max tires. The date indicates that they were produce in May of 2015. The coach has at on a seasonal site since 2016 and showed no signs of dry rot. We will pick the rig up in a couple of weeks. I think my plan is to use the current tires for our last trip of the year when we pick it up and then replace the tires next spring. they are "G" rated tires.
fj12ryder
Platte City, MO
Posted: 10/01/20 07:42am Link  |  Quote  |  Print  |  Notify Moderator
So the tires are 5 years old, and they've been sitting for 4 years. If your last trip is fairly short, and not several hours of high speed travel, it might be okay. But, personally, I would be concerned with old tires that have been sitting for years. But that's just me.
Howard and Peggy
"Don't Panic"
JIMNLIN
Oklahoma
Posted: 10/01/20 08:11am Link  |  Quote  |  Print  |  Notify Moderator
Ahh yes... Tow Max tires. Their know as blow max around the commercial trailer industry. And about the same around many rv websites.
Generally 16" load G tires were aimed at the regional service trailer industry and have a much better service life on road trailers than 15/16/14" load E/D/C blow max sizes.
Tire rot.... or what ever you call it may or may not show on the outside but those type issues can start internally. The tire may look new on the outside.
Your way over tired on the trailer so those load G are no where near max loads so with your smaller trailer they should be fine. Just make sure you have a good spare aired to the max.
mkirsch
Rochester, NY
Posted: 10/01/20 11:52am Link  |  Quote  |  Print  |  Notify Moderator
Yup, time to replace the tires.
Don't know about "aired to the max" advice though. Seems to me if the tires are way overrated for their application and being run at max air, the trailer is going to be receiving a VERY jarring ride, being launched to the moon every time you hit a pothole.
mrad
Prineton, MN
Posted: 10/01/20 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
When I replace them, am I better off putting E rated back on if that keeps them within range? E was original equipment with G being an option.
fj12ryder
Platte City, MO
Posted: 10/01/20 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
What are they being put on?
mrad
Prineton, MN
Posted: 10/01/20 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
ToyHauler
fj12ryder
Platte City, MO
Posted: 10/01/20 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
mrad wrote:
ToyHauler
Well then, round and black and full of air should work just fine.
 > Tow King Tires
