RV.Net Open Roads Forum: New truck - but its lifted and towing
 > New truck - but its lifted and towing
samhain7
Toronto
Posted: 09/28/20 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Hi all.
Just upgraded to a 2016 Dodge 2500 Laramie with a Cummins. It's a beauty!
However, I get it this weekend and have a camping trip right after.
It's lifted about 3" I would say.
My trailer is in the signature. 2014 Starcraft Autumn Ridge 28 ft.
I don't imagine towing with a lifted truck is good. But my question is, do I go on my upcoming trip (about 2 hours away), or do I rush the truck in to the get spacers removed.
I realize if it stays I will have to readjust my sway set up.
Thanks!
Final notice from MasterCard. Good! I'm sick of hearing from them.
2016 Dodge Ram 2500 Cummins, E2 WD w/sway
2015 Starcraft Autumn Ridge 289BHS
CA Traveler
The Western States
Posted: 09/28/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
Remove the spacers (best) or use a drop down hitch.
2014 Grand Cherokee Overland
Bob
bob213
Fresno, CA
Posted: 09/28/20 10:53am Link  |  Quote  |  Print  |  Notify Moderator
If you like the lift then keep it and get a hitch with a larger drop on it.
afidel
Cleveland
Posted: 09/28/20 11:11am Link  |  Quote  |  Print  |  Notify Moderator
Do you know your loaded hitch weight? If not assume ~1,000 pounds. Compare that plus whatever people and cargo you'll have in the truck against the payload of a power wagon (~1500) and you'll get an idea of how urgently you need to remove the lift.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
near Bishop, California
Posted: 09/28/20 11:39am Link  |  Quote  |  Print  |  Notify Moderator
"I realize if it stays I will have to readjust my sway set up."
You might have difficultly finding a drop down sway hitch.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
mooky stinks
Cicero,NY
Posted: 09/28/20 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
There's probably more lifted trucks towing campers around here than factory height trucks. As long as your hitch is adjusted properly, don't even worry about it. You'll always have the worry warts that have never done it telling you how "dangerous" it is!
mooky stinks
Cicero,NY
Posted: 09/28/20 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
Why would the OP compare his truck to a Power Wagon? That's a totally different suspension than a lifted 2500. His is obviously not a Power Wagon as it has a Cummins in it.
jdc1
Rescue, Ca
Posted: 09/28/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Spacers, longer springs, and longer shocks are part of a lift kit. A-arm replacement might also be part of that lift kit. Yea....just get a drop down hitch, otherwise you'll need to remove a lot more than just spacers....and you'd need a front end alignment and head light adjustment after removing the whole lift kit, front and back.
MitchF150
Puyallup, WA
Posted: 09/28/20 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, just get the proper drop hitch shank for the hitch to keep the trailer as level as you can get... It can be a WD hitch or just a drop on depending on the TW of the trailer..
Good luck! Mitch
samhain7
Toronto
Posted: 09/28/20 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks all for the replies.
My hitch can actually be flipped upside down to lower it. So i will do that and try to level the trailer with what I have.
