RV.Net Open Roads Forum: Class C Motorhomes: camco wave 3 heater QUESTION
 > camco wave 3 heater QUESTION
midnightsadie
ohio
Posted: 09/28/20 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
seen at a garage sale a camco wave 3 heater my question is are these the ones safe to use inside a rv? SMALL CLASS c NEW IN THE BOX.
jdc1
Rescue, Ca
Posted: 09/28/20 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
That's what they are made for. But, they only heat small areas.
Camping near Pearsonville, CA
Posted: 09/28/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Others don’t believe they are safe when you are sleeping. Plus they don’t keep the tanks warm.
bobndot
Posted: 09/28/20 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
3000 btu’s is not a lot of heat. It would take the chill out of the air once you have had it on for an hour or so. You would have keep a vent cracked open to ventilate. You have to mount it so you dont burn anything above it. I prefer a portable Mr Heater from 4000-9000 btu’s. I like the option to move it around as needed.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 09/28/20 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
We just finished using one for two weeks while out moose hunting in camper on the back of a Nodwell with the temps in the 40s. We turned it off a couple of nights because it go to warm. It was a 16' camper.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
ReneeG
Meridian, Idaho
Posted: 09/29/20 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
We too use a Mr Heater Big Buddy for affordability over the Wave, but it's the same concept. Only uses propane and no electricity.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
rexlion
Broken Arrow OK
Posted: 09/29/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Safe if you follow directions and crack open a couple of windows a bit; they do use up oxygen over time which must be replenished, but as long as they get proper oxygen they produce considerably less carbon monoxide than other non-vented, open-flame heaters.
Mike G.
--for now, using a cargo trailer for camping--
Those who would give up essential liberty, to purchase a little temporary safety, deserve neither liberty nor safety. --Benjamin Franklin
photo: Yosemite Valley view from Taft Point
pianotuna
Regina, SK, Canada
Posted: 09/29/20 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
I won't use an unvented combustion heater.
If you insist on having one, definitely ventilate and do not use when sleeping.
There are many vented combustion heaters that use no electricity and are safe to use.
Regards, Don
memtb
Wyoming
Posted: 09/30/20 07:49am Link  |  Quote  |  Print  |  Notify Moderator
We have one in both our class c and our 5’er. We only use them when temperatures are not expected to get and remain below freezing. If the temps get and stay quite cool, we need the forced-air to heat basement tanks and water system.
We added two (2) additional CO monitors, for security reasons. You must keep adequate ventilation in the camper to keep the monitors from going off. In summary they do help keep the rv warm, but, I highly recommend taking precautions by having additional Co monitors. I suggest at least two (2), as one may fail....not likely that two (2) will fail! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
