RobWNY
Jamestown, NY
I have aluminum studs and want to attach a TV bracket. Any ideas on which brand would be best with density?
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Cummins12V98
on the road
Middle knuckle on right hand.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Dick_B
Palos Heights, IL USA
When all else fails they can sometimes be spotted from the outside in the morning condensation.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
garyemunson
Reno, Nevada
As a coincidence, my old studfinder bit the dust a few months back. Replaced it with this. REALLY good quality tool. Solid feel to it unlike the plastic box thing I'd had before. Works well and has settings for both wood and metal studs. Good price.
https://www.amazon.com/TACKLIFE-Scanner-........aWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
edited 09/29/20 09:44am by an administrator/moderator *
RobWNY
Jamestown, NY
Thanks everyone
RCMAN46
NorthWest
Dick_B wrote: When all else fails they can sometimes be spotted from the outside in the morning condensation.
X2 and I took pictures of all the outside walls so I could use the information in the future.
Lynnmor
Red Lion
Aluminum framed trailers may have as few as three studs over the entire length of the side. The wall may have steel sheet metal just under the paneling for attaching a TV and it can be found with a strong magnet. A stud finder for wooden studs will be pretty much useless. If you had a sticker showing the TV mount location then go by that, if you want an alternate location, good luck. Contact the manufacturer if in doubt.
RobWNY
Jamestown, NY
Lynnmor wrote: Aluminum framed trailers may have as few as three studs over the entire length of the side. The wall may have steel sheet metal just under the paneling for attaching a TV and it can be found with a strong magnet. A stud finder for wooden studs will be pretty much useless. If you had a sticker showing the TV mount location then go by that, if you want an alternate location, good luck. Contact the manufacturer if in doubt.
That's the problem Lynnmor, there is a sticker and I've talked with three different people that used the sticker for guidance on the exact same RV that I have and the sticker had been placed in the wrong spot. I'm not drilling pilot holes only to learn some flunkie put the sticker in the wrong place.
jdc1
Rescue, Ca
Knock knock.
NRALIFR
Truck Camping Out West
This always works for me.
![[image]](https://i.imgur.com/rlODhHSl.jpg)
![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
2001 Lance 1121 on a 2016 F450
