RV.Net Open Roads Forum: General RVing Issues: Stud Finders
 > Stud Finders
wopachop
Who run bartertown
Posted: 09/29/20 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Donut shaped neodymium magnet on a string. It finds the fasteners.
Home depot has them in the hardware section.
Lynnmor
Red Lion
Posted: 09/29/20 03:15pm Link  |  Quote  |  Print  |  Notify Moderator
RobWNY wrote:
Lynnmor wrote:
Aluminum framed trailers may have as few as three studs over the entire length of the side. The wall may have steel sheet metal just under the paneling for attaching a TV and it can be found with a strong magnet. A stud finder for wooden studs will be pretty much useless. If you had a sticker showing the TV mount location then go by that, if you want an alternate location, good luck. Contact the manufacturer if in doubt.
That's the problem Lynnmor, there is a sticker and I've talked with three different people that used the sticker for guidance on the exact same RV that I have and the sticker had been placed in the wrong spot. I'm not drilling pilot holes only to learn some flunkie put the sticker in the wrong place.
Did you try the magnet? If you find a square of sheet metal, then fasten the mount with sheet metal screws. Folks drill and think there is nothing in there but the drill goes thru the sheet metal quickly. Then there are those that use wood screws that destroy the pilot hole. Use #8 or #10 screws that will enter the wall about 1/2" using a pilot hole the root diameter of the screw.
Posted: 09/29/20 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
I recall a device and I ***THINK*** it is the device IU will provide a link to that was advertised on TV a while back that could see through walls. It could not only detect wood/metal studs but things like rats and mice
https://walabot.com/see-through-walls
RCMAN46
NorthWest
Posted: 09/29/20 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I looked up this device on Amazon. It appears it will only work with Android phones.
It also has a 11 percent one star rating.
CavemanCharlie
Storden,MN
Posted: 09/30/20 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
I'm a stud will it find me ????
(Sorry, I know this post was not helpful to the thread but, I've always wanted to say that.)
Posted: 09/30/20 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, was gonna say...All I do is look in a mirror. Works every time!
2017 Heartland Torque T29
Posted: 10/01/20 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Regarding using a magnet to find the fasteners. Aluminum studs one should use aluminum screws (NOTE THE KEY WORD SHOULD, Does not mean they do)
And I'm glad I added the ***THINK*** to the wal-bot )
When I was looking for it I found several competing products
Lynnmor
Red Lion
Posted: 10/01/20 08:03am Link  |  Quote  |  Print  |  Notify Moderator
It is STEEL sheet metal you are looking for. A simple magnet will work, the OP has not mentioned if he tried it.
Cummins12V98
on the road
Posted: 10/01/20 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Aluminum screws, hmmm.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
caver
Missouri, The Cave State
Posted: 10/02/20 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Project Farm just evaluated a bunch of stud finders.
 > Stud Finders
