RV.Net Open Roads Forum: Slide Out and Hot Water Heater Not Working
 > Slide Out and Hot Water Heater Not Working
CPTArcher
Castor, LA
Posted: 09/29/20 09:57am Link  |  Quote  |  Print  |  Notify Moderator
The slide out and gas/electric hot water heater is not working on my 2014 26ft bumper pull Aspen Trail travel trailer.
Swapping relay on my slide out did not fix issue. Fuses are good. Push switch on slide out and nothing happens. Can open manually.
Light on switch for heater comes on but water never changes temp. Not sure if issues are connected or separate issues.
Trailer is being used as hunting camp, so moving at the moment is extremely difficult.
My initial thought is a critter may have chewed the wires but I am not seeing any visual sign of damage/entry from a casual inspection.
Probably causes? Where do I should I start troubleshooting?
Any help is greatly appreciated.
* This post was last edited 09/29/20 10:28am by CPTArcher *   View edit history
jdc1
Rescue, Ca
Posted: 09/29/20 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Start with the propane.....
CPTArcher
Castor, LA
Posted: 09/29/20 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the response.
Propane is full and doesn't work when using electric either.
Old-Biscuit
Verde Valley
Posted: 09/29/20 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Slide out and water heater both use DC BUT are separate issues
Slideout...typically wired directly to battery POS post with an in-line fuse (or DC Circuit Breaker) so start at battery and follow smaller individual wires to the fuse/CB and check if blown/tripped
Water heater....
Could be Main DC Fuse bad, could be tripped t-stat, could be Fuse on water heater circuit board, could be circuit board
It would help if you posted Brand/Model of water heater
US NAVY------USS Decatur DDG31
CPTArcher
Castor, LA
Posted: 10/03/20 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Water heater....
It’s an Atwood 6 gallon.
LVJJJ
NW WASHINGTON
Posted: 10/14/20 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
AHA! Atwood, that's your problem. I have had nothing but problems with every Atwood appliance I've ever had. Two water heaters had propane, burner problems. Furnaces give up and sound like a super sonic jet when they fire up. Get a Suburban. Neighbor had an Atwood furnance in her park model (we live in a gated RV park) and we also live in a park model. We have a Coleman furnace. Since the neighbor is Canadian and doesn't come down in the winter, I've had to call the service guy two winters in a row to fix her furnace. Nothing but hassles with Atwoods. They should not be allowed to be on the market.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
