RV.Net Open Roads Forum: Tech Issues: Connecting Portable Solar Panels
 > Connecting Portable Solar Panels
obiwancanoli
Napa
Posted: 09/29/20 09:58am Link  |  Quote  |  Print  |  Notify Moderator
As I've been exploring an upgrade of my entire electrical system, I'm contemplating adding additional solar, and looking at options.
I have plenty of room on the roof for a few more panels, though I probably need only 2, at around 300-600W added to my current 480W panels, and a 120W portable. Four Battle Born Lithium batteries are probably installed by now, along with a Victron 100A/50 MPPT controller, and 712 Voltmeter. Given those hot days when you'd prefer to be under some shade, it seemed having a portable would be prudent for those times when you need to be more judicious by having solar you can actually point at the sun.
Thus, I am thinking it might be prudent to add at least ONE portable, maybe up to 300W perhaps, and I had a couple questions for y'all... first, does it make sense for me to consider an additional portable, and if so, how long of an extension cord should I consider? Is 20 ft sufficient, or is 30 ft a more practical length?
Second, can two - or more - portable panels be tied together so that only one lead goes to the batteries? I've looked on Amazon, but amongst the multitude of pages I must sift through, I confess my patience was challenged, and I gave up before having any success in finding a 2-into-1 fitting that combines the two...
* This post was edited 09/29/20 04:36pm by obiwancanoli *
madjack60
littleton
Posted: 09/29/20 10:03am Link  |  Quote  |  Print  |  Notify Moderator
Ebay has lots of 2 into 1 upto r into 1 spliters. You may want to check if your charge controller can handle all the extra wattage.
Camping near Pearsonville, CA
Posted: 09/29/20 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Wouldn't the weight of a 300 watt "portable" solar panel be 50-60 pounds?
pianotuna
Regina, SK, Canada
Posted: 09/29/20 10:07am Link  |  Quote  |  Print  |  Notify Moderator
you will soon tire of deploying portable panels.
Regards, Don
2oldman
The Q
Posted: 09/29/20 10:20am Link  |  Quote  |  Print  |  Notify Moderator
To the controller.. sure. You don't need special connectors, just wire them up yourself.
obiwancanoli
Napa
Posted: 09/29/20 10:32am Link  |  Quote  |  Print  |  Notify Moderator
That may be, but if it's the only way to charge the batteries, best to be able to tap into the sun
Posted: 09/29/20 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I'd get very tired quickly moving around a 50 to 60 pound panel. And where would you store it?
jaycocreek
Idaho
Posted: 09/29/20 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Portable solar is about the only way I could use solar camping in the deep forest hardly ever in the sun.As far as how many feet of cable,it depends on where your camping..I am using about 30ft or just shy of it in this pic.
As far as always moving the panels,you don't have to but if you do,you get the most watts to the battery..Just laying my panels flat like it would be on the roof,I lost a bunch of watts..LOL
1994 F-350 DRW /460/k&n intake /415# torque/lance 9.6/Engel compressor fridge/3 gr 27 batteries/Honda 2k/Honda 3K/WH Camo 2250/Reese solid bar extension/Buddy heater/3 inverters//Happi Jack tie downs /Firestone bags/Yamaha Rhino/Winch and Lockers
2oldman
The Q
Posted: 09/29/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
The longer the cord the more loss. Consider a series hookup if much over 20'. A 300w panel will likely be 24v.
* This post was edited 09/29/20 11:58am by 2oldman *
jaycocreek
Idaho
Posted: 09/29/20 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
While this is true,it can easily be a non issue by buying quality portable solar panels with 23-25% efficiency compared to the cheaper 18% or so..Some of the top names are not the top performers.
If the op is serious about portable solar,I strongly suggest he looks up Hoboteck on youtube and watch as he compares the portable solar panels one on one/side by side..Quite interesting...
