RV.Net Open Roads Forum: General RVing Issues: Winterizing Travel Trailer
 > Winterizing Travel Trailer
Sjm9911
New Jersey
Posted: 09/30/20 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
Use the antifreeze. Using air can work, but sometimes it dosent get all the water out, then it settles and crack. This, as stated happens around the water pump also. My buddy was a air guy for 20 ywars untill he split his water pump one year. Also, dont forget to take care of or remove the batteries.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
CavemanCharlie
Storden,MN
Posted: 09/30/20 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, I do the opposite of what some of the posters here said. I run the pink antifreeze through first, and then I blow it out. That way the pink stuff is not setting in the lines all winter long and it's easier and quicker to get rid of the smell of it in the spring.
magicbus
Nantucket Island, MA
Posted: 09/30/20 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Huh, and I thought I’d avoid adding yet another option because I always open my low points and faucets after using pink stuff. As you said, less to clear out come warm weather.
Apparently there are 4 or 5 sides to this coin and 50% of Rver’s choose one those of those multiple methods.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
d3500ram
Colorado
Posted: 09/30/20 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
When I had my TC's, I would do similar... only just opening everything and let the RVAF just drain out and then store the camper without any pressurized lines. I never left full lines as the AF did it's job by displacing water.
I would do this many time in the winter because I was using it often for hunting or ski-camping around the state during winter.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
Bobbo
Wherever I park
Posted: 09/30/20 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
Terryallan wrote:
Now next thing. IF you use the winterizing kit inside the RV. Please remember to let the antifreeze run out the city water connector. There is a button inside the hose connector that you can press with a screw driver. However, Remember to stand to one side, as there will be pressure on it. Ask me how I know.
Never, EVER, do this while the water system is pressurized. It can blow the O-ring out of the backflow preventer. After everything else is full of antifreeze, open the kitchen tap to release the pressure, and leaving that tap open as a vent, press that button on the shore water inlet. There will be enough pressure from the full water lines higher than the inlet to make the antifreeze flow back out of the inlet, protecting it.
Bobbo and Lin
ReneeG
Meridian, Idaho
Posted: 10/01/20 07:05am Link  |  Quote  |  Print  |  Notify Moderator
I mentioned this to hubby and he said he's thought of doing this too. He only pumps it through the pipes and faucets, but we still have a heck of a time in the spring getting rid of the leftovers so this might help.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Terryallan
Foothills NC
Posted: 10/01/20 09:11am Link  |  Quote  |  Print  |  Notify Moderator
kellem wrote:
Terryallan wrote:
You would feel better using antifreeze. And be safer.
Truth is. IF you are going to run antifreeze thru it. Blowing it out first is a waste of time. The antifreeze will displace any water in the system. that is what it does.
Be careful with relief valve on the city water hookup as you could potentially lose the seal under pressure.
Best way I've found was to relieve some pressure at the outside shower or sink with the water pump off before pressing on city valve.
Exactly. Should have said to release a little pressure. My bad
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
milo
4 Corners
Posted: 10/09/20 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Sorry folks..but the only way to make sure the pump in our 5'er is winterized is to put some antifreeze into the FW tank and suck it thru the pump. Pump has no winterizing kit attached to it and is not accessible to put one on it. So I run it for 10 or 15 seconds to make sure all water is out of it and then add just enough antifreeze to the tank so the pump will pick it up, then drain the remaining out. Also there's no gravity hole to fill FW tank so I have to pump it in with another pump. We have a lever to switch from tank fill or city water usage. Been doing this now for the 7 years we've had it. Come spring I sanitize the tank & system good with bleach and have had no antifreeze foam or after taste.
Milo
Janet & Milo ...43 3/4 fantastic yrs 2gether ">
Mona Mo 11 yr old F Yorkie & (in spirit) Buddy our beloved Beagle
2013 F-150 Kodiak Brown XLT 4X4 HD Ecoboost
2014 Cougar 26sab
Living under the best Government money can buy ... Bob Brinker ">
tomman58
Southeast Michigan
Posted: 10/09/20 07:11am Link  |  Quote  |  Print  |  Notify Moderator
remember the hose connection and after you do the pink use a screw driver to push the small white plastic valve in the hose fitting. Do not stand in front of it !!!
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
AJR
Close to Madison Wisconsin
Posted: 10/09/20 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Always used pink stuff. Never had a problem.
2014 Leprechaun 290QB
Chevy 2400 6.0
2015 GMC Terrain AWD
