RV.Net Open Roads Forum: General RVing Issues: Winterizing Travel Trailer
 > Winterizing Travel Trailer
Super_Dave
Harrisville, UT
Posted: 10/10/20 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
milo wrote:
Sorry folks..but the only way to make sure the pump in our 5'er is winterized is to put some antifreeze into the FW tank and suck it thru the pump. Pump has no winterizing kit attached to it and is not accessible to put one on it. So I run it for 10 or 15 seconds to make sure all water is out of it and then add just enough antifreeze to the tank so the pump will pick it up, then drain the remaining out. Also there's no gravity hole to fill FW tank so I have to pump it in with another pump. We have a lever to switch from tank fill or city water usage. Been doing this now for the 7 years we've had it. Come spring I sanitize the tank & system good with bleach and have had no antifreeze foam or after taste.
Milo
Milo, why do you think that the pump isn't getting winterized by sucking the antifreeze out of the jug?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
milo
4 Corners
Posted: 10/17/20 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Super Dave
Cuz where the pump is, in the lower half of a little cabinet in the back corner of the 5'er under the electrical junction box which is in the upper half of the cabinet. There is no room to add a hose so the pump can suck antifreeze out of a jug. I don't trust just running the pump dry that all the water is out of it.
Impossible to add a winterization kit to this mess. Would have to take apart the cabinet just to get to the pump. 2nd pic, if you look really hard you can see the pump in the back left side of the picture. So I have to put some antifreeze in the tank so the pump can suck some thru it.
Milo
Janet & Milo ...43 3/4 fantastic yrs 2gether ">
Mona Mo 11 yr old F Yorkie & (in spirit) Buddy our beloved Beagle
2013 F-150 Kodiak Brown XLT 4X4 HD Ecoboost
2014 Cougar 26sab
Living under the best Government money can buy ... Bob Brinker ">
