RV.Net Open Roads Forum: Beginning RVing: One night stays and black/grey tanks
 > One night stays and black/grey tanks
time2roll
Posted: 09/30/20 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Best approach?
Sometimes it is actually way easier to do something you are not inclined to do. Just run with the tank part full already. Couple times and you will get over it and not miss the daily dump one bit.
That or use the community bathhouse for your needs.
675w Solar pictures back up
wopachop
Who run bartertown
Posted: 09/30/20 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
Raife wrote:
more the travel weight and if the tank can handle the weight bumping along the road.
What type of RV? For peace of mind you can crawl underneath and visually inspect the tank supports. Look for bending, loose nuts. I hold 200 gallons of fresh and fill that sucker to the brim before camping trips. No joke i was just under the trailer 30 mins ago inspecting my tank braces. Im sanitizing the tanks is why im under there. Pulling the drain to get the bleach water out.
Camping near Pearsonville, CA
Posted: 09/30/20 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
I’m of a whole different mindset regarding water use if I’m staying one night in a camp with a dump and fresh water than I am when I find a beautiful dry sight and want to stay awhile, and whenever possible I fill the black tank before dumping. That’s “clean enough” for me.
Sjm9911
New Jersey
Posted: 09/30/20 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
It shouldent get that full on one night , let it ride, dump on the second. Dont over think it.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
PastorCharlie
NC
Posted: 09/30/20 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
One holds the black tank contents in their intestines longer than a couple days before dumping in the black tank. Sometimes it causes an odor while there.
valhalla360
No paticular place.
Posted: 09/30/20 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Raife wrote:
I'm not concerned about the black nasty stuff, more the travel weight and if the tank can handle the weight bumping along the road...I have read some stories of dropping the black tank...
Dump every 2nd or 3rd night. If a few gallons causes the tank to fall off, you needed to replace it anyway.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
jdc1
Rescue, Ca
Posted: 09/30/20 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
And....you do not need any additives. Those tanks are just buckets with lids....not a septic system. If you smell odors, you have other problems.
Posted: 09/30/20 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
Raife wrote:
Thoughts on what the best approach is?
Thank you.
Dump when it needs dumped and don't worry about hauling some water around.
Whatever concerns you have about packing a few hundred lbs of water with are likely unfounded. Enjoy the trip, not the dump stations.
If you cannot stand traveling with water in, just dump them regardless of how full they are. It's nice to have enough gray to dump to wash the Baby Ruths out of the hose from the black dump though.
pianotuna
Regina, SK, Canada
Posted: 09/30/20 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
What sort of RV do you have?
Regards, Don
2chiefsRus
USA Somewhere
Posted: 10/01/20 04:12am Link  |  Quote  |  Print  |  Notify Moderator
if you are concerned about weight, it would be nice to know if you are traveling with a nearly empty 40 foot motorhome or a nearly maxed out on weight travel trailer? or somewhere in between. more information would give you better answers. otherwise everyone assumes you have an rv like they have.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
